Garage Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2010, 10:36 AM   #1
garage wiring
Would it be up to code in the state of Colorado to use romex in a garage that has no drywall?
jmc1981 is offline   Reply With Quote
Old 10-31-2010, 11:03 PM   #2
RST
DIY Homeowner
Rewards Points: 150
This doesn't answer your question, but it might be helpful:
http://www.familyhandyman.com/DIY-Pr...age-unfinished
RST
RST is offline   Reply With Quote
The Following User Says Thank You to RST For This Useful Post:
jmc1981 (11-01-2010)
Old 11-01-2010, 08:24 AM   #3
thanks I was pretty sure it had to be this way.
Old 11-01-2010, 08:55 AM   #4
Run along a stud is usually OK
Drilling holes & running wiring between studs may not be OK
Must be protected from physical damage if the key
Inspectors sometimes see this in a different way
Might want to check with your local inspector 1st
I'd say tons of sheds are wired without sheetrock/wall covering & wiring exposed
Mine is & passed inspection
Old 11-01-2010, 10:55 PM   #5
firehawkmph's Avatar
Rewards Points: 2,474
JMC,
Best and easiest thing to do is call your local building department and just ask. Saves a lot of headaches. A lot of cities around by me want any romex covered with drywall on the wall areas.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Old 11-02-2010, 12:11 AM   #6
" Euro " electrician
frenchelectrican's Avatar
One of few legit way is run the romex along the stud up and down way but not the horzontal runs it is not legit in most area when the garage wall is exposed.
Othewise the sleeved conduit will work for this purpose.
{ check the local office on latter part due some can allow and some don't }
Merci.
Marc
Wiring house to garage stonehaven Electrical 7 06-02-2010 06:19 PM
wiring code w.r.t. NEW folding stairs in garage attic fredsterl Electrical 4 09-25-2009 11:05 PM
Wiring garage workshop Kay Man Electrical 10 08-28-2008 12:04 PM
wiring garage clive Electrical 6 08-20-2008 12:36 PM
Wiring my garage with direct burial cable? Earl Smith Electrical 3 08-10-2008 06:28 PM
