Garage Door Opener Breaker And Outlet - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2010, 10:20 PM   #1
Rewards Points: 97
garage door opener breaker and outlet
i have to replace the garage door openers ( 20 yrs old) and am wondering if the current powering scheme is ok
there are two 1/3 HP openers with common 3-prong cords plugged into two separate 15A duplex outlets mounted on the garage ceiling (sheetrock). the outlets are being fed by surface-mounted romex connected to a 15A GFCI in one of the bathrooms. this circuit has only 5 outlets, 2 in baths, one on the outside wall and 2 in the garage for openers. the main-panel breaker is also 15A
1. is 15A ok?
2. any issue with the circuit being shared with bath outlets and the outside outlet?
thanks
drgkjd is offline   Reply With Quote
Old 05-21-2010, 10:26 PM   #2
Bathrooms need a dedicated 20a GFCI circuit these days
Bathroom circuit can feed outlets in multiple bathrooms only
Garages require GFCI & it should not be fed by the bathroom
The Following User Says Thank You to Scuba_Dave For This Useful Post:
drgkjd (05-22-2010)
Old 05-22-2010, 03:28 AM   #3
" Euro " electrician
frenchelectrican's Avatar
1. is 15A ok?
thanks
That was legal in old code editon but per today codes requirement it is not legit at all.
So the only way you can do this is sepearted the bathroom circuit from the garage door opener circuit and also the outdoor receptale is no longer allowed to be on bathroom circuit.
I know in older codes they use one GFCI device to handle bathroom , garage , outdoor and some case kitchen circuits { I have see it once a while }
Merci,Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
drgkjd (05-22-2010)
Old 05-22-2010, 08:00 AM   #4
Rewards Points: 2,800
Assuming the existing 15 amp circuit runs to the bathrooms first, you really need to string a new 20 amp circuit to the garage ceiling and outdoor receptacle and perhaps some additional garage receptacles, putting a GFCI unit in the first outlet box.
But until then you should be able to plug the new garage door openers into the existing, unmodified, receptacles on the garage ceiling.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
The Following User Says Thank You to AllanJ For This Useful Post:
drgkjd (05-22-2010)
Old 05-22-2010, 09:14 AM   #5
Rewards Points: 97
yes, the 15A circuit's first stop is the bath outlet..... from there it goes to other outlets.
Old 05-22-2010, 09:22 AM   #6
Rewards Points: 97
must i modify?
so now i have to ask-- do i have to modify to comply with current codes or can i leave it the the way it is since it was compliant at the time of construction (1986)?
thanks all for your very helpful quick response.
Old 05-22-2010, 11:59 AM   #7
Master Electrician
Rewards Points: 5,082
If it hasn't been a problem all these years why are you changing it?
brric is offline   Reply With Quote
Old 05-22-2010, 04:18 PM   #8
Rewards Points: 97
if your "changing" applies to wiring, i am not anxious to change....that is the question i am asking....
.....do i have to change ( because i am changing the opener)?
i am changing the opener because it is on its way out...(over 20yrs old)
thanks
Old 05-22-2010, 04:58 PM   #9
Master Electrician
No. You do not have to change the wiring because you are replacing the openers.
The Following User Says Thank You to brric For This Useful Post:
drgkjd (05-22-2010)
Need a 220 Volt Outlet in garage, what to do? gante Electrical 6 04-11-2010 10:53 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
Outlet in garage quit working Thirdeye Electrical 10 07-01-2007 10:32 PM
Kitchen outlet breaker simma Electrical 3 02-28-2007 05:50 PM
