Garage Cable - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-02-2015, 09:26 AM   #16
Rewards Points: 204
"B" in UF-B means it is suitable for burial without a conduit.
Its PVC jacket is extra tough and decay-resistant.
Both UF and UF-B have gray sheaths most of the time.
Nutmegger is offline   Reply With Quote
Old 06-02-2015, 09:28 AM   #17
Rewards Points: 204
Originally Posted by crescere View Post
If I do go under the sidewalk how deep do I have to make the trench under cement?
Check this out:
http://www.xwalk.com/images/Table_30...over_Reqts.pdf
To translate, 18 inches for direct buried, 12 inches if in PVC.
That's from the surface to the TOP of the conduit or the cable.
Old 06-02-2015, 11:21 AM   #18
A "Handy Husband"
rjniles's Avatar
Rewards Points: 894
The B has nothing to do with burial. All UF is rated for direct burial. The UF-B is a newer cable that replaced type UF.
My electrical answers are based on 2017 NEC, you may have local amendments.
Old 06-02-2015, 11:39 AM   #19
Rewards Points: 204
Cerrowire sales rep told me this.
Doesn't mean he's right, but just what I've heard from the sales guy.
Old 06-02-2015, 11:46 AM   #20
Rewards Points: 2,350
The B means it has 90 degree C conductors.
The Following User Says Thank You to InPhase277 For This Useful Post:
rjniles (06-02-2015)
Old 06-02-2015, 01:18 PM   #21
Licensed electrician
Rewards Points: 3,848
Wow, was he working in the paint aisle last week?
Old 06-02-2015, 04:10 PM   #22
Rewards Points: 204
You'd think I was .. I should know these things
Gettin' old.
I think I should stay retired
Old 06-04-2015, 01:20 PM   #23
Rewards Points: 740
The guy at HD (he is a retired master electrician) said to use aluminum SER 2224 under the crawl, then put a junction box outside the house, then run aluminum URD 4 in conduit under the sidewalk, and to the panel in the garage. This would be WAY cheaper than $400 for 6-3 UF-B copper.
crescere is offline   Reply With Quote
Old 06-05-2015, 08:22 AM   #24
Rewards Points: 740
Are there any opinions on the above recommendation? I just want to learn more about this.
My Cable TV Project (Advice Needed) 95PGTTech Electrical 19 08-30-2014 03:59 PM
Underground power run to detached garage has failed-what to do now? BT5150 Electrical 8 06-26-2012 08:15 PM
Running cable to a detached garage Kastern Electrical 3 10-05-2011 07:17 AM
Garage door cable problems. Blondesense General DIY Discussions 6 03-23-2010 06:22 PM
Attached Garage, No sub panel, seperate grounding rod danocars Electrical 6 03-15-2010 05:27 PM
