Furnace Wire Into Liquid Tite - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By JimmyJones99
Old 09-14-2019, 02:11 AM   #1
Rewards Points: 38
Furnace wire into liquid tite
My furnace wire comes down a stud and through drywall and into the furnace. I need protection on the exposed part (4") where it comes out of the drywall. Can i run liquid tite from furnace into wall cavity and just strip a foot of sheathing off of the cable and run it into the liquid tite or do i need something else?
JimmyJones99 is offline   Reply With Quote
Old 09-14-2019, 04:46 AM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,902
Re: Furnace wire into liquid tite
and into the furnace. I need protection on the exposed part (4") ...
You do?
TarheelTerp is online now   Reply With Quote
Old 09-14-2019, 08:07 AM   #3
Rewards Points: 88
If this furnace is not within sight of your main breaker box, then hopefully there is a disconnect or electrical box mounted on the furnace that is being used as the furnace means of disconnect.
If NOT, then now is the opportunity to set a junction box(or disconnect) over that exposed Romex coming out of the wall and then run metal flexible conduit from it, in to the furnace.
Install the properly rated switch (or disconnect) for the furnace and then you have killed two birds with one stone.
If the furnace does have a means of disconnect on it and it is sitting within 4 inches of the wall, you could just attach something to the wall to protect it. And not have to go to the work of disconnecingt the furnace power wires while working them through a flex. JMO
Gregsoldtruck79 is offline   Reply With Quote
Old 09-14-2019, 11:50 AM   #4
Rewards Points: 38
Originally Posted by TarheelTerp View Post
You do?
Yes you can't have unprotected wire below 6' i believe it is.
Old 09-14-2019, 12:30 PM   #5
Rewards Points: 38
Yeah that makes a lot of sense, i suppose just a little ply box around it is acceptable.
Old 09-14-2019, 12:42 PM   #6
Rewards Points: 88
Does the furnace have a on/off main power switch on it ?
Or is it sitting within sight of the breaker box that has the breaker in it, that turns the furnace on or off ?
Or is there a disconnect that controls the furnace within sight, close by ?
Old 09-14-2019, 12:50 PM   #7
Rewards Points: 38
Yeah it's about 4 feet away from main panel.
Gregsoldtruck79 likes this.
