Furnace Outlet/switch Problem? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2009, 02:48 PM   #1
furnace outlet/switch problem?
I have a switch with outlet on furnace, the switch for power on furnace works. the outlet for humidifier,air cleaner does not any ideas?
cinders is offline   Reply With Quote
Old 12-12-2009, 03:22 PM   #2
Check your circuit breakers. Could be on a different circuit.
Try plugging something else in like a can opener from the kitchen. Does that work in the outlet?
Billy_Bob is offline   Reply With Quote
Old 12-12-2009, 03:48 PM   #3
breakers fine put tester on outlet, nothing. outlet has white wire going to neutral. one black wire for humidifier, one for electic air cleaner going to main control. switch has black wire for power,one for furnace both hot!
Old 12-12-2009, 06:58 PM   #4
An old Tradesmen
Rewards Points: 2,930
The EAC terminal of a furnace board. Is only energized when the blower is on.
The HUM terminal may be a 120 volt, or 24 volt terminal, depending on furnace.
Old 12-13-2009, 09:51 AM   #5
Arrow
furnace is trane american standard freedom 90 model #auc080c942b7. how can i check if control board is good? kinda lost right now!!
Old 12-13-2009, 11:15 AM   #6
An old Tradesmen
Measure the voltage output of the terminals.
Install manual will tell you what voltage your HUM terminal is.
Old 12-13-2009, 11:22 AM   #7
Go back and do what post #2 suggested with the can opener or similar.
Also re re read post #4 and make sure the blower is running when you try #2.
SULTINI is offline   Reply With Quote
Old 12-14-2009, 05:44 PM   #8
have power when blower runs, found out humistat doesn't work unhooked wires and touched together and humidifier ran so maybe that is problem. next up is the electric air cleaner. no power to that when blower is running, now what??
Old 12-14-2009, 06:46 PM   #9
An old Tradesmen
Did you check for voltage from the EAC terminal.
Old 12-14-2009, 07:14 PM   #10
For the electronic air cleaner, first read the owner's instruction manual. This should tell you about if it has a circuit breaker inside you could reset or a fuse you could replace. And about how to clean it.
If you don't have the owner's manual, you might be able to go to the manufacturer's web site and find one.
Then other than that, you should know how to use a voltmeter and know how to work on electronic equipment. There is probably high voltage present and you could easily shock yourself if you are not familiar with how these operate.
If you do understand electronics, you may be able to get a service manual from the manufacturer. This would explain the circuit design and show tests to check various components or at least have a schematic diagram.
Basically you need to understand how it works - how it should work - before you could test anything and determine if a component was doing what it should or not.
Old 12-15-2009, 06:40 PM   #11
can't seem to find manual. I'll have to check website it's an enviracaire elite F300 1019. I'll see what honeywell has to offer then go from there.
Old 12-15-2009, 07:24 PM   #12
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
Do you have a neutral? Do you have a hot?
Then what's the problem?
And they say electrical's easy
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 12-18-2009, 06:14 PM   #13
found out humidstat was bad, replaced with new unit and all is good. eliminated electronic aircleaner, replaced with paper filter with less headaches. thanks for all the help from everyone!!
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Old Silver-Line furnace problem avro1 HVAC 9 03-18-2010 12:01 AM
Strange Problem with My Furnace chenjijc HVAC 14 11-04-2009 09:05 PM
Carrier Furnace Problem Boats1183 HVAC 1 11-11-2008 06:41 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 02:04 PM
