Fried Neutral Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 05:02 PM   #16
Rewards Points: 3,416
If the neutral has come loose from the bus bar in the panel, it will be hot if you tried to turn something on on that circuit.
Stick to your lawn watering schedule until it really pours. Otherwise the storm might miss and the part that gets watered last (3 days away?) will dry up.
Old 09-18-2011, 06:09 PM   #17
Missouri Bound's Avatar
Rewards Points: 3,544
Originally Posted by sobro View Post
Also, when I use my voltage detector, I noticed that the neutral (the fried one) also appears to be hot. Is this normal? It's off that 20A breaker, so I wasn't sure...
A "voltage detector" as you call it is just that...it alerts you to the presence of voltage. It, at best is a preliminary device and certainly not a tester you want to trust with your life or safety. They are notorious for false indication.
Old 09-18-2011, 06:14 PM   #18
Super Moderator
joed's Avatar
Rewards Points: 31,940
The 20 amp breaker is correct only IF the entire circuit is wired with #12 wire.
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Multi Wire Branch Circuit MWBC w/4X or 6X hots or more, 1X oversized neutral mysterylectric Electrical 7 05-05-2011 10:16 PM
my neighbor is using my neutral wire, is he stealing my electricty? stanlam Electrical 17 08-26-2009 07:45 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Sub panel grounding sluggermike Electrical 27 11-11-2007 01:23 AM
