Framing For Vanity Light Bar - Electrical - DIY Chatroom Home Improvement Forum
Old 07-23-2010, 01:24 PM   #1
Hi all. Working on a full gutting of the bathroom and about to install the new vanity light (its a bar style).
I haven't drywalled yet and I have steel studs if thats relevant.
The box needs to be roughly centered between two studs.
How do I create something so that the box is at the right depth with the finished wall and not protrude oddly?
While an 'old work' box would probably support the fixture (it's not that heavy), considering the wall is down I'd rather use a new work box and do it more solidly.
I'd sort of expect there is some sort of hanger or box+2x4 solution for this but looking for the experienced advice on what I should be doing.
Thanks,
David
Ugh. Sorry for the duplicate posts! Had an Internet hiccup and can't figure out how to delete one of them.
-no problem - 2 threads merged
Moderator
schnitz411 is offline   Reply With Quote
Old 07-23-2010, 01:50 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 694
Run a piece of blocking between the studs and attach the box to the blocking. I would use a scrap of 2x4 and a nail on octagonal box. Install the box so the front edge is flush with the finished wall.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 07-23-2010, 02:00 PM   #3
Electrician
Proby's Avatar
You could just pickup a round box with universal bar hanger for under $5 at Home Depot or Lowes.
Proby is offline   Reply With Quote
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 04:28 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 07:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 09:02 AM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Need to replace can light with standard light Woodcutter Electrical 3 02-29-2008 07:06 AM
