Foreign Lightbulbs (Chinese) - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2016, 09:52 AM   #1
Rewards Points: 2
Question
I'm not sure if anyone would know this but thought it was worth a shot.
I'm trying to figure out if Chinese lightbulbs will work in the US. I have the specs for the Chinese bulbs but they are LED bulbs and I'm having a hard time figuring out how to convert the specs to American specs to see if they are compatible.
I read (Google) that European bulbs are made for 220 so they can be used in the US but will be dimmer because we use 110. But I can't find anything like that on Chinese bulbs.
Anyone have any information/knowledge that might help?
Thanks in advance for your time.
Tami Brock
NoviceDIY-er is offline   Reply With Quote
Old 06-02-2016, 10:07 AM   #2
Rewards Points: 62
Voltage , frequency , base size. If it's not UL approved then don't buy the unsafe China crap. If it's not approved for use in North America and you burn your house down, you are at fault.
psgama is offline   Reply With Quote
Old 06-02-2016, 11:02 AM   #3
Rewards Points: 2,730
Re: Foreign Lightbulbs (Chinese)
A 220 volt or 240 volt LED lamp may or may not work at all on 120 volts.
While you could construct a fixture with a transformer for the lamps, the fixture would not be "approved" e.g. with the Underwriters Labs seal of approval.
What are the specs you have?
Heat went off in the dead of winter? Excellent idea to be late or absent for work and to spend the day winterizing your house to keep pipes from freezing. Every house is different. For those of you not hit yet, think of what things you need to do.
Old 06-02-2016, 06:25 PM   #4
dmxtothemax's Avatar
Rewards Points: 7,316
Tami Brock
1 - Depends on the voltage rating
if they say 120v yes they work
if they say 220/230/240 no they may not work.
2 - how do you convert Chinese spec's to American spec's ?
please elaborate ?
3 - The chinese do make 120v Led lamps as well,
But 220v are NOT what you want.
you want 120v led lamps.
4 - Be careful as the quality of some Chinese can be quite poor.
dmxtothemax is online now   Reply With Quote
Old 06-02-2016, 09:13 PM   #5
Rewards Points: 4
Also want to know!
derrickfan is offline   Reply With Quote
Old 06-02-2016, 11:29 PM   #6
Originally Posted by derrickfan View Post
Also want to know!
What do you want to know ?
Weather you can use 220v Leds on 120V ?
The answer is NO !
If you want to buy chinese Leds then they must be 120v not 240v.
They do make 120v versions as well.
Old 06-02-2016, 11:47 PM   #7
Rewards Points: 2,332
Mains voltage LED lamps are usually specified as being designed to operate on either
AC 110 V to 120 V
AC 220 V to 240 V
AC 86 V to 265 V
- or similar ranges of voltages.
Those that have specifications like "AC 86 V to 265 V" (like many small current devices) would have a "Switch Mode" Power Supply and are unlikely to be "dimmable".
FrodoOne is offline   Reply With Quote
Old 06-03-2016, 02:29 AM   #8
I have the specs for the Chinese bulbs. Tami Brock
can you post a picture of these spec's please ?
Or post a link ?
Affordable Freestanding Tub Fill - Chinese? zippinbye Kitchen & Bath Remodeling 1 01-20-2015 05:22 PM
smelly lightbulbs bucksone Electrical 2 06-04-2012 03:37 PM
Lightbulbs in Ceiling Fan! kateisstumped Electrical 5 07-20-2011 12:06 PM
