From Flush-mount To Surface-mount - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By betelgeuse
Old 07-30-2020, 07:58 PM   #1
Rewards Points: 42
From flush-mount to surface-mount
I have a flush-mounted (in-wall) quad receptacle box, in a commercial setting. I need to move the receptacles to a different location on the same wall, but for several reasons I don’t want to cut into the wall to establish a new, flush-mount location. My idea is to convert the current receptacle box to a junction box, then install one of those front covers with the knock-out in the center, and from there run a surface-mounted conduit to a new, surface-mounted receptacle box in the new location. Does the code allow me to do this?
Thank you for the help.
Rollie83 is offline   Reply With Quote
Old 07-30-2020, 08:16 PM   #2
Licensed electrician
Rewards Points: 4,142
Re: From flush-mount to surface-mount
Wiremold makes extension boxes to do exactly what you want. However, being commercial should have a licensed contractor perform the work for liability reasons.
Old 07-31-2020, 09:05 AM   #3
Red Seal Electrician
Rewards Points: 334
It can definitely be done. Not difficult.
https://www.familyhandyman.com/list/...rical-conduit/
If something happens to end up not being up to code, it's easy to change or remove because it's not buried in a wall
u2slow is offline   Reply With Quote
Old 08-01-2020, 08:24 AM   #4
Ret. Elec. Contractor
Rewards Points: 178
https://www.homedepot.com/p/4-in-x-1...-187/202097248
This will mount to either a single gang or 2 gang box by just turning the box 90. The holes lines up with the 6-32 device attachment screws.
Sparkyb60 likes this.
betelgeuse is offline   Reply With Quote
Old 08-01-2020, 11:45 AM   #5
Rewards Points: 58
A blank plate with a knock-out (hole) will not allow you access to the wiring once you install the conduit.
Wiredindallas is offline   Reply With Quote
Old 08-01-2020, 12:23 PM   #6
Rewards Points: 1,896
Yeah, they're called box extensions.
- If you already have a mud ring and have 2 gangs, use Betelgeuse's box (slick by the way!)
- If you want a neater installation, use a Legrand Wiremold Surface Conduit Starter Box (also good for getting some extra cubic inches).
- If you just have the 2 corner screws on a 4x4 box, any $1.50 4x4 extension box will do the trick.
All these have open bottoms on the box, specifically so you can reach through the box and get access to wires etc.
seharper is online now   Reply With Quote
Old 08-01-2020, 10:20 PM   #7
Rewards Points: 42
Ah, that's a great point, and it hadn't occurred to me.
Thank you.
