Fluke Multimeter - Electrical - DIY Chatroom Home Improvement Forum
Old 06-19-2010, 07:02 PM   #1
jburd964's Avatar
Rewards Points: 172
Fluke Multimeter
I'm not a electrician but have a Fluke 21 multimeter. I'm doing some work on my house and get a .0L code every now and again, I'm clueless any help would be appreciated.
jburd964 is offline   Reply With Quote
Old 06-19-2010, 07:51 PM   #2
Master Electrician
Rewards Points: 5,116
The input is too large for the selected range.
brric is offline   Reply With Quote
Old 06-19-2010, 07:51 PM   #3
It means Over Load. Too many volts/amps/ohms.
Old 06-19-2010, 08:16 PM   #4
I=E/R
a7ecorsair's Avatar
I'm pretty sure this meter is auto-ranging so unless you exceed the limits it should choose the correct range.
First thing, make sure you choose the correct function for the task you are performing.
What are you testing with the meter, AC volts, DC volts, or resistance / continuity?
a7ecorsair is offline   Reply With Quote
Old 06-19-2010, 08:40 PM   #5
As others have said, overload.
If your measuring resistance and don't have the leads touching anything, this is normal as your resistance is infinite (to the meter).
If your measuring voltage or amperage, you might have accidentally hit the range button and taken it off autorange. Hit the hold the range button for a few seconds and it should go back to autorange. Turning it off and on will do the same thing.
Here is a link to the manual.
http://www.tequipment.net/pdf/77,75,..._InstSheet.pdf
tdeg807 is offline   Reply With Quote
Old 06-19-2010, 10:04 PM   #6
jburd964's Avatar
Rewards Points: 172
The meter is a Fluke 21 series II multimeter. I'm measuring voltage 110 with meter sat for ACV's. The settings are on a manual dial. Would having the polarity reversed cause .0L reading??
Old 06-19-2010, 10:19 PM   #7
The leads have to be plugged into the correct jacks. Some functions of the meter might already be clobbered.
Old 06-19-2010, 11:26 PM   #8
I=E/R
a7ecorsair's Avatar
If you are measuring AC voltage there is no polarity, either lead to either point.
I know Fluke had problems with one model several years ago and those in my service group who had them had to send them in. I'm quite sure it was a 2x model.
Do you know the history of this meter? I looked at Fluke's web site and they have manuals for many models but not the 21.
http://us.fluke.com/fluke/usen/Suppo...ls/default.htm
Old 06-19-2010, 11:30 PM   #9
jburd964's Avatar
Rewards Points: 172
I looked for Series II as will and haven't found them either.
Old 06-20-2010, 01:18 AM   #10
Mad Scientist
Does the "OL" indication just flash up briefly? I have a Gardner-Bender autoranging meter that will show OL for a second when I first connect it to something, before showing the proper reading. It's because it starts out in a low range, say 0-500mV, and moves up through the ranges until it's in the right range for whatever voltage I'm measuring.
So if it's an autoranging meter, and it just shows briefly, it's perfectly normal.
McSteve is offline   Reply With Quote
Old 06-20-2010, 11:05 AM   #11
Rewards Points: 310
Some models of Fluke meters use the "OL" designation as open. Meaning with leads touched together you read ohms. If you take the leads apart the meter reads "OL". I have one that works like this and it is completely normal.
Try it and see.
The Following User Says Thank You to J. V. For This Useful Post:
jburd964 (06-20-2010)
Old 06-21-2010, 08:59 PM   #12
jburd964's Avatar
Rewards Points: 172
Hey I just I had inadvertently been hitting the zero are calibrate button by accident. When it did it today i reset it and the OL code went away. Thanks for the help. I may be back with more question.
Testing Batteries With a Multimeter Kent10 Electrical 17 01-17-2011 09:55 AM
Using a multimeter inside a panel secutanudu Electrical 8 02-17-2010 01:23 PM
Using a multimeter to test a 50 amp receptacle WendyS Electrical 12 01-22-2010 09:10 AM
multimeter question spikesnet Electrical 3 10-20-2008 11:21 AM
Need help identifying multimeter ToddB64 Electrical 9 11-10-2007 01:50 AM
