In Floor Heating System - Electrical - DIY Chatroom Home Improvement Forum
Old 07-12-2010, 01:31 PM   #1
in floor heating system
Hi All,
I'm about to install a "true comfort MAT" from TRAME. The question I have is do I really need a dedicated circuit for this? It says it should be on it's own, but the specs for the one I have (which is the smallest you can get- small bathroom) is for only 104 watts (120 V). Now, does that really warrant pulling a new line half way across my house? The only other things on the existing circuit is a light fixture, extractor fan and GFCI outlet (which feeds the light and fan). Can't I just piggyback off the existing GFCI or is there some other reason that I can't think of? Maybe they are just looking for excuses to not honor their warranty if the thing fails (I'm guessing lot's of people will skip pulling another line). Or maybe it's just a blanket guideline that includes the very large mats that probably do need more power. Anyway, hoping for some insights from you guys.
Thanks!
zantar is offline   Reply With Quote
Old 07-12-2010, 04:11 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 952
We are taught by code to install by manufactures spec, so the correct answer is a dedicated circuit.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 07-13-2010, 12:44 PM   #3
Okay. Thanks for the advice.
beware humidity system? Emaderton3 HVAC 5 02-10-2010 11:52 PM
Burnham Series 2 Cast Iron Radiator System SybrDave HVAC 2 12-10-2009 05:24 AM
new system install.....questions firedogut HVAC 4 10-04-2009 07:10 PM
Installing a New Central Air System vdu HVAC 7 09-01-2009 03:45 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 07:22 PM
