Flexible PVC Conduit Question - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By brric
Old 06-19-2017, 05:27 PM   #1
Location: Well, I'm North of I-10, but South of I-94. And, West of I-95, but East of I-5...
Rewards Points: 92
Hello all,
I have two 1" PVC conduit sections. I wish to connect the two sections with a 2' piece of flexible, non-water tight PVC conduit. However, so far, the flexible conduit has a water tight seal, or some other end piece that does not match a normal PVC conduit. How do I get this to work?
South Taco is offline   Reply With Quote
Old 06-19-2017, 05:44 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 694
Re: Flexible PVC Conduit Question
Female adapter on the PVC, male adapter on the flex.
Sent from my RCT6203W46 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 06-19-2017, 06:44 PM   #3
Master Electrician
Rewards Points: 5,082
Where did you find non-water tight flexible pvc? Are you talking about ENT(electrical nonmetallic tubing)? Commonly referred to as smurf tube.
MTN REMODEL LLC likes this.
brric is offline   Reply With Quote
Old 06-19-2017, 08:54 PM   #4
Rewards Points: 92
I haven't found anything but many feet of water tight conduit, which I do not need. all I need is a small section of flexible 1" that hooks to my typical 1" PVC conduit.
Old 06-19-2017, 08:55 PM   #5
Rewards Points: 92
I'm confused, what type of adapter? Do I buy flexible water tight, and simply cut off a piece, and the adapter slips on?
Old 06-19-2017, 09:02 PM   #6
Electrical Contractor
jbfan's Avatar
Rewards Points: 952
How about a picture or link.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 06-19-2017, 09:36 PM   #7
Master Electrician
Here is one brand of LFNMC connectors. Other brands are available as well as connectors for LFMC
Old 06-19-2017, 09:40 PM   #8
Master Electrician
[ATTACH][/ATTACH]
One type of liquid tight flexible metallic conduit (LFMC) connector.
Old 06-19-2017, 09:44 PM   #9
Master Electrician
This fitting is glued on to the rigid pvc.
Pvc female adapter
Old 06-20-2017, 09:20 PM   #10
Rewards Points: 92
Attachment 391690
Pvc female adapter
Oh...I get it now, the adapter is a typical 1" female threaded adapter. I see.
Now, the problem is I only need a couple of feet, not 25'
Thanks for the help
Old 06-20-2017, 09:59 PM   #11
Master Electrician
Use these and cement them to the pipe.
My supply house sells LFNMC by the foot.
Old 07-07-2017, 08:53 AM   #12
Rewards Points: 92
Attachment 392050
This worked out well, thank you
Question on conduit for exposed wiring in finished garage garya505 Electrical 54 01-02-2012 12:38 PM
Conduit Question md2lgyk Electrical 5 08-20-2011 06:45 AM
Replacing Metal timer box with Plastic - Metal conduit question? TFastle Electrical 6 12-20-2010 05:54 AM
easy question - PVC conduit connection to main panel tpagel Electrical 14 07-17-2009 06:50 PM
Basement Electrical- Flexible Conduit? H Thomas Electrical 2 04-20-2006 08:42 PM
