Fixture With No Colored Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 11-29-2013, 04:07 PM   #1
Fixture with no colored wires
I have a simple lighting fixture I want to install; it has two wires and a ground wire, but the wires are not sheathed in plain cable, in other words, not delineated white or black.
Is this a safe fixture to install, and if so, anything I need to know about attaching to the black and white wires in the box?
tominrichmond is offline   Reply With Quote
Old 11-29-2013, 04:17 PM   #2
Licensed electrician
Rewards Points: 3,654
The ribbed or identified conductor splices to the white from the ceiling.
Old 11-29-2013, 04:55 PM   #3
Don't see any ribbing or other obvious indicator. Any ideas, or should I just chuck it?
Old 11-29-2013, 05:07 PM   #4
Oso954's Avatar
Rewards Points: 2,152
Use your fingers to feel the clear insulation. You can generally feel the ribbing (ridges) easier than seeing them. Some wires will have a single rib, while others use multiple ribs.
The ultimate test is to use either an ohm meter or a continuity meter. One of those wires will have continuity between the end and the threaded portion of the socket. That would be the neutral.
The other wire would show continuity with the raised blade in the bottom of the socket. That would be the hot.
I generally mark the hot with a large black band, put on with a sharpie.
That way you can readily ID it next time.
Oso954 is online now   Reply With Quote
Old 11-29-2013, 05:14 PM   #5
It's easy to check with a multimeter. Set your meter to continuity and place one lead on the little metal tab at the bottom of the base where the lightbulb screws in. Put the other lead on one of the wires. If it beeps you have found your hot.
hacksawjiw is offline   Reply With Quote
Light Fixture With Multiple Wires Hippy007 Electrical 5 11-01-2012 12:54 AM
NEC and Hanging Fixture Wires teedoe Electrical 11 10-02-2012 11:36 AM
overhead light fixture has 9 wires? pokey1984 Electrical 8 11-14-2011 08:04 PM
How many wires can be tapped into a light fixture? JayBird Electrical 6 07-11-2011 02:44 PM
ceiling fixture wires - neon tester glows when off 1611mac Electrical 4 04-18-2010 09:07 AM
