Five-gang Box Extension - Electrical - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 09:47 PM   #1
Rewards Points: 522
Five-gang box extension
I'm going to be putting a five-gang electrical box in a wall that's going to be covered with a 1-1/4" granite backsplash.
Does somebody make an extension for a five-device box, or do I need to put the receptacle/switch tabs directly on the granite and use longer screws?
benjamincall is offline   Reply With Quote
Old 06-26-2010, 10:04 PM   #2
Licensed electrician
Rewards Points: 3,662
The maximum setback allowed with a non-combustible material like granite is 1/4". You will need to use box extenders. Arlington makes ones called BE-1 and BE-2 that are gangable.
aifittings.com
Old 06-26-2010, 10:34 PM   #3
Rewards Points: 522
aifittings.com
Great! Amazon sells a five-pack for eleven bucks. That should do the trick.
http://www.amazon.com/gp/product/B00...f?ie=UTF8&s=hi
Garage Door Extension Spring Question kmc143 Building & Construction 4 02-23-2010 08:24 AM
2 gang old box, made into 3 gang, off center?? fabian Electrical 9 01-15-2010 09:46 AM
I can't find 16 gauge heavy duty extension cord! darsunt Electrical 21 08-04-2009 07:50 PM
Extension Cord Safety Ultrarunner2017 Electrical 23 01-20-2009 09:11 PM
Air Compressor stopped working, extension cord was used. dawho1 Tools 3 10-07-2008 05:14 AM
