Finer Points Of Armored Cable - Electrical - DIY Chatroom Home Improvement Forum
Old 06-02-2010, 11:47 AM   #1
Rewards Points: 165
Finer Points of Armored Cable
When running 3/8" AC into a box, do you end the armored cable and protective bushing at the clamp just outside the box? This is how I've seen some instructions do it, but I have been able to thread the armored cable (the metal part), by turning through the fitting so there is a length of metal cable in the box. The bushing then goes on it. This appears to be a much more secure way to do this, as the other approach looks like you could pull it out easily as the only thing holding it is the screw. Is this "into the box" approach acceptable?
smata67 is offline   Reply With Quote
Old 06-02-2010, 03:16 PM   #2
Rewards Points: 2,800
YOu should be able to fasten the cable in place with no more than a quarter inch protruding in past the box itself. (Not 1/4 inch past the rim of the clamp.)
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 06-02-2010, 03:30 PM   #3
Master Electrician
Rewards Points: 5,082
You have the wrong fittings. AC will not protrude into a box if you have the proper box connectors.
brric is online now   Reply With Quote
Old 06-02-2010, 03:35 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
agreed.
AC fittings have material across the front of them to prevent the sheath from intruding beyond the fitting.
Old 06-02-2010, 05:20 PM   #5
Rewards Points: 165
That is the fitting I'm using. This is the 3/8" cable and it can be rotated in past the hole and into the box. This is much more secure than pushing it into the clamp on the outside and securing with a screw. Either way, the bushing works, but perhaps it is held in place better when you don't put it through the hole.
This looks like it would work better than a set screw type, but I've not seen them at HD.
Old 06-02-2010, 05:22 PM   #6
Master Electrician
there's a line of code in the CEC that states how much sheath your allowed to have in the box....i think with AC it's 0. Not sure what the NEC states although i'm sure there's a similar rule.
andrew79 is offline   Reply With Quote
Old 06-02-2010, 05:26 PM   #7
Master Electrician
You have a fitting that is too large for the AC you are using. Why ask for advice if you're going to argue about a proper installation?
Old 06-02-2010, 06:09 PM   #8
nap
You talking to me?
nap's Avatar
if you use the proper fitting, the sheath will not fit through the hole. AC comes in a variety of sizes due to the size and count of the conductors. The insulator will probable not simply stick into the end and stay.
You just simply need to get the proper fittings for the size of cable you have.
Simple test for the right fittings:
if the sheath can pass through the fitting, it's the wrong fitting.
Armored Cable Question jlaky2000 Electrical 17 12-01-2008 09:07 PM
NM to Armored Cable Transition? toddmanqa Electrical 8 10-31-2008 03:29 PM
armored cable tomfag Electrical 25 10-30-2008 08:24 AM
1930s armored cable wiring Lisa_90 Electrical 9 08-01-2008 09:24 AM
Which type of Armored cable. helpless handyman Electrical 4 12-01-2007 09:04 PM
