DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   Feeding surface mount receptacles via Romex (https://www.diychatroom.com/f18/feeding-surface-mount-receptacles-via-romex-657949/)
alexjburkhardt 04-25-2019 11:14 AM
Hi All,
Just a sanity check here. I'm looking to add some additional outlets to my garage via a circuit that is fed with 12/2 romex.
Garage has two walls facing the living space and are finished with drywall. Remaining 2 walls are unfinished block to the outside.
The circuit i'm pulling from was originally supplying power to a whole house central vacuum, which is no long in place. Whomever did the work ran romex to one of the exterior walls, then did a straight drop down the block into a surface mount single gang box into which the vac was plugged.
I will be running conduit from the box around the room to provide additional power, but would like to remedy the current exposed-romex situation. I'll also be adding GFCI protection at this point to protect the rest of the receptacles.
Is the proper fix to surface mount a j-box at the ceiling where the romex exits, then run my THHN down via from there via conduit? Would a flush mount box be preferred?
Is there a conduit body style that can exit the ceiling drywall in which i can transition to THHN?
Looking for suggestions on the cleanest way to transition to 1/2" EMT from a romex feed originating in the ceiling.
Thanks!
Yodaman 04-25-2019 11:45 AM
Re: Feeding surface mount receptacles via Romex
from your existing ceiling box get a cover with a round knock out in it. Then use a 90 degree conduit adapter.
http://cdn.mrsupply.com/image.php?type=P&id=50027
curiousB 04-25-2019 11:47 AM
1 Attachment(s)
Get a box extender and fasten to existing flush box. Then use one of the side knockouts to start the conduit run. Done all the time.
alexjburkhardt 04-25-2019 11:48 AM
My apologies -- "straight drop" down from the ceiling may have insinuated there was an existing ceiling box -- there is not. Just 12-2 NM, presumably stapled to the joist, then snaked down through the ceiling drywall.
curiousB 04-25-2019 11:52 AM
then mounts an octagon box to the ceiling. Use the center knockout in the back of the box to put a NM connector to fasten the existing cable. Then run conduit out the side knockouts.
rjniles 04-25-2019 12:21 PM
Just pull the existing Romex into a conduit sleeve to the box. I would replace the existing single gang with s 4" to prove room for splicing.
Sent from my Moto E (4) Plus using Tapatalk
alexjburkhardt 04-25-2019 12:56 PM
Forgive my ignorance. I was under the impression that NM wasn't allowed to be run in conduit, but in truth, i don't know what i'm talking about. I can't say i can picture how i'd secure at the ceiling joint, either, unless maybe i just extend the conduit through the ceiling drywall so nothing is exposed.
As long as i'm going to be in there, I think i'll likely mount a junction box and be done with it. Seems to be the most appropriate solution, with really no extra effort.
thanks, all.
joed 04-25-2019 01:18 PM
It is not permitted in a complete conduit system, box at both ends. However with an open end conduit is considered a sleeve for protection and is permitted. So run the NM down the wall into the box and transition to THHN for the rest of the conduit system.
rjniles 04-25-2019 01:22 PM
If the poster is in the US, the NEC allows Romex in any dry location conduit system.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
