Feeder Ditch Inspection Help - Electrical - DIY Chatroom Home Improvement Forum
Old 08-11-2013, 05:49 PM   #1
macon, ga bibb county
Rewards Points: 150
Feeder ditch inspection help
I'm. Wanting to have my ditch depth and conduit inspected going from my existing sub to a new one out back in my shop, what all needs to be done other than all the conduit ran and glued up (empty).? Or is that it?
Lupus71 is offline   Reply With Quote
Old 08-11-2013, 06:40 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
You may want to consult your AHJ as to what they will allow.
Around here, we just do the whole thing and leave both ends open.
wirenut1110 is offline   Reply With Quote
Old 08-11-2013, 10:46 PM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,112
For an open trench inspection I need to see the conduit in the ground. Don't care if the conductors are installed or not.
All responses based on the 2014 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 08-12-2013, 02:00 AM   #4
" Euro " electrician
frenchelectrican's Avatar
One of my Inspector in France got smart and he do take veido of the whole conduit before it buried and he do allow it in few case but there are couple special step it have to be done in veido inspection.
But genrally they ( Inspectors ) will check the depth and type of conduit and size of conduit. unless you got direct burial SWA cable then will check the depth and proper bonding on SWA cable.
Merci,
Marc
Old 08-12-2013, 08:05 AM   #5
Rewards Points: 150
Thanks! Called him to come check it out. If it passes what are the steps for running the wire? I would pull it through obviously then would I hook it up and turn all the sub panels off for inspection and install all my outlets and lights?
Old 08-12-2013, 08:33 AM   #6
electures's Avatar
It varies from job to job if it is a small job, I'll call for the open trench and final at the same time. Since you are doing the work, install all the conductors and terminate. Then schedule a rough inspection. You could also ask your inspector what he needs to see.
Marc, I know it is common practice to video or take pictures, or provide site posts. I have accepted this practice from contractors on occasion, but only from contractors I have worked with for a period of time. I think our other professionals will understand the relationship we have established over time. My advice is that inspections are visual and not all inspectors will accept this practice. Inspectors need to seethe back fill and the depth for the entire trench. We also at need to see the burial warning tape. Ask the inspector what he needs to see.
Now if a vibratory plow is used then no inspection is needed
The Following User Says Thank You to electures For This Useful Post:
frenchelectrican (08-12-2013)
Old 08-13-2013, 09:32 AM   #7
Rewards Points: 150
So would the final inspection include my feeder wire install and all the outlets installed and everything inside the new building? Also on the rough he said I missed two grounds in boxes but said continue project so would only need the final now or will he need to recheck for those grounds first? Sorry I know I should call him but he is only there for 1 hr and its hard to get him. He has passed the trench inspection also. Thanks for the help so far guys!
Old 08-13-2013, 09:39 AM   #8
Rewards Points: 150
Everything should have power hooked up and hot right? Should I keep the doors off of the panels so he can see or is that too dangerous?
Old 08-13-2013, 10:22 AM   #9
electures's Avatar
Finish the job and call for a final. If he wants covers off he will ask. Just make sure all the walls and ceiling have been roughed inspected.
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 03:19 PM
drainage ditch stagnant water denemante Landscaping & Lawn Care 6 05-17-2011 11:58 AM
How to Keep Gravel from Washing Out of Drainage Ditch Jaylyn Landscaping & Lawn Care 4 01-27-2011 06:17 PM
drainage ditch NHO Landscaping & Lawn Care 1 04-03-2009 02:37 PM
2x100a sub on service main jambud Electrical 17 03-12-2008 09:31 AM
