Fed Pacific Breaker Question And Advice Needed - Electrical - DIY Chatroom Home Improvement Forum
Old 03-22-2010, 11:29 AM   #1
Fed Pacific breaker question and advice needed
I just purchased a home with a Federal Pacific breaker box. I assume they are the stab-lok breakers. I have read a lot of the information about what happened with these breakers and that Fed Pac. is no longer in business.
The one for the water heater is on a 2-pole, 30 amp breaker. When I turned the water and electric back on, the water heater worked for a while but tripped the breaker. I reset it and it worked for one day. Now my water heater no longer works. I checked to see if current was going to the water heater. No current is getting to the water heater but the breaker has not been tripped. If the breaker has failed, how do I tell and is there a reliable source for replacements?
Any suggestions about what to do next?
itsallhistory is offline   Reply With Quote
Old 03-22-2010, 03:28 PM   #2
the best replacement option would be a new panel. I have seen one of these panels burn a house down its nothing you want in your house.
naehring2000 is offline   Reply With Quote
Old 03-22-2010, 04:00 PM   #3
Thanks for the advice. I'm considering using a Square D box and breakers.
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Ridge Vent/Soffit Advice Needed kw151002 Building & Construction 5 06-26-2009 01:26 PM
Help needed on electrical question Partisan Electrical 9 02-25-2009 02:00 PM
Breaker Question Hardlyable Electrical 4 01-29-2009 07:32 PM
Max amps allowed - electrician advice needed Des Electrical 27 06-05-2008 10:31 PM
