Is This Feasible ? ? ? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-30-2010, 02:12 PM   #1
Question
HOW Does This Work ? ? ?
Im trying to DIY on this one with supplies from lowes maybe.
POWER CORD:
# 1 - 30 Amp Dryer Cord
BREAKERS:
# 1 - 20 Amp Breaker 240 volt
# 1 - 10 Amp Breaker 120 volt
RECEPTACLES:
# 4 - 240 volt Receptacles
# 2 - 120 volt Receptacles
HolidayMagic is offline   Reply With Quote
Old 01-30-2010, 02:37 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
What is that abomination???
How about some 20A breakers.
And what is a "trigger cable"?
Old 01-30-2010, 02:43 PM   #3
its like a relay.
its for an outdoor lighting timer.
found it online but it is kind of pricey.
Thinking it would be better to build something like this myself.
Old 01-30-2010, 03:04 PM   #4
I used Intermatic timers, I have (5) now (3 are on the far right in this pic)
4 of them control (2) 20 circuits each
The 4th is digital & controls (4) 20a circuit
They are usually about $45 - $40 with 10% off coupon
I picked up 2 of them for $7 each on clearance
Old 01-30-2010, 05:07 PM   #5
It would help when asking a question like this if you posted the site where you saw that and any technical specifications they had there...
But I would "guess" that they are just using a "contactor" and the "trigger cable" just activates the contactor. A contactor is just an electrically operated switch also called a relay.
But contactors are designed to be mounted in a box like above. Relays are pretty much designed to be installed on a printed circuit board. And in vehicles they are frequently called solenoids.
But all the same thing - relay...
How a relay works...
http://www.google.com/search?hl=en&s...h&aq=f&aqi=&oq=
Billy_Bob is offline   Reply With Quote
Old 01-30-2010, 05:17 PM   #6
yeah looks like a power distribution box that takes a 240V circuit and turns it into multiple 120V outlets which are timed on a contactor relay.
Commonly used for HID lighting etc.
wtfh4xx is offline   Reply With Quote
Old 01-30-2010, 05:59 PM   #7
Question
The Specifications
POWER CORD:
1 - 30 Amp 3-Prong Dryer Cord
BREAKERS:
2 - 30 Amp Breaker 120 volt
RECEPTACLES:
4 - 120 volt Receptacles
Looking for a wiring diagram and maybe a parts list to make this exact setup.
Old 01-30-2010, 06:08 PM   #8
The 30A breakers are a violation.
Why not use four 20A breakers instead? One for each duplex?
Also, a 4-wire dryer cord and circuit would be MANDATORY!
Old 01-30-2010, 06:37 PM   #9
Question
Is this feasible ? ? ?
Old 01-30-2010, 06:44 PM   #10
Old 01-30-2010, 08:08 PM   #11
Idiot Emeritus
Rewards Points: 80
The diagram shows 240 volts applied to the receptacles. That would be a problem.
That set-up certainly could be built using a 4 wire dryer cord and 20 amp breakers. The 120 volt trigger cord would work as-is.
It's really nothing more than a portable sub-panel with a relay to control the receptacles.
If you're going to use this for outside stuff, GFIs would be needed as well.
Rob
micromind is offline   Reply With Quote
adding subpanel in attic -- is this feasible? jayp Electrical 8 05-22-2009 10:22 AM
LED track lighting feasible yet? GFW Electrical 8 01-22-2009 12:13 PM
Hybrid Deck - Is Pressure Treated + Composite Feasible? kyassassin Building & Construction 4 01-15-2009 08:33 PM
burying CPVC under concrete amakarevic Plumbing 17 03-25-2008 08:45 AM
DIY replacement of neo angle shower enclosure feasible? hfoster Remodeling 4 02-14-2008 09:38 PM
