Fastening Multiples Wires - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2010, 05:35 AM   #1
Rewards Points: 93
fastening multiples wires
Do they make or what do use to clamp/fasten/staple multiple wire together, say three or four 12/2's?
bfan781 is offline   Reply With Quote
Old 03-28-2010, 07:23 AM   #2
Remodeling Contractor
you do not do this at junction boxes. each wire should be stapled individually. but going into the panel you can buy bundle supports that is made for this purpose. (not staples)
Old 03-28-2010, 08:28 AM   #3
Licensed electrician
Rewards Points: 3,654
Most staples for the correct cable size are only for 1-2 cables. For multiple cables something like the 3M Stak-it could be used.
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
Is this normal? 20A circuit 20A wires feed 15A wires walt1122 Electrical 14 02-06-2010 02:44 PM
Can't find the wires! brianmarsh Home Theater 2 01-24-2010 07:11 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
