Fail Safe Power Outlet Need Schematic - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-31-2009, 01:40 PM   #16
1geo
1geo's Avatar
I checked out the RS site and they have everything except the reset switch. That should be no problem, in fact, I may have one on a piece of equipment I can pull. The pump I am trying to control draws about 26 watts so its well below the limit of the relay. Thanks for all your help. I'll post once I finish the circuit and let everyone know how it turned out. Thanks again, Geo.
1geo is offline   Reply With Quote
Old 07-31-2009, 03:02 PM   #17
$6 for Hosfelt part number #45-699 120v coil relay.
Old 08-01-2009, 05:19 PM   #18
1geo
1geo's Avatar
Parts
I went to radio shack today and bought all the components. They have everything in stock except the relay which they ordered. I have everything already mounted in an aluminum box waiting for the relay which hopefully will come next week. I'll keep the thread going until I put the fail safe box together and test it out.
Old 08-02-2009, 12:44 AM   #19
DIYer
You can just buy this.
http://www.stayonline.com/detail.aspx?ID=10956
Or this:
http://www.stayonline.com/detail.aspx?ID=13897
It's what I did for a stereo that made a loud noise when the power failed and came back on.
Gigs is offline   Reply With Quote
Old 08-02-2009, 06:38 AM   #20
1geo
1geo's Avatar
Both of these are GFCI outlets. GFCI do not trip on a power loss but upon sensing a ground. So, these would not solve my problem.
Old 08-02-2009, 07:45 AM   #21
Rewards Points: 1,192
The portable G.F.I. cords I use have to be reset everytime you lose power.
bobelectric is offline   Reply With Quote
Old 08-02-2009, 08:09 AM   #22
Rewards Points: 2,350
He's probably got half the cost of those GFCIs in his home made box. And he gets the satisfaction of building it himself. If the relay ever fails, he can just plug a new one in.
Old 08-02-2009, 11:38 AM   #23
J. V.'s Avatar
Rewards Points: 348
Originally Posted by 1geo View Post
Yoyizit, I am 71 years old and need a picture to follow when hooking up something. Your instructions are good but I'm not sure I could follow them. Geo.
No one can follow his advice. He reinvents the wheel in every post and confuses the hell out of people. Maybe he is so smart he has no common sense. Just ignore him and listen to InPhase. Theres your help. And it is easy to understand.
Who said relays were expensive? You can buy a miniature relay with base for less than an upper end duplex receptacle. IDEC is a good inexpensive brand. Weg is another.
Old 08-02-2009, 11:47 AM   #24
OUCH!
BTW, are you the guy who said Grainger never helped anyone?
Old 08-02-2009, 01:10 PM   #25
1geo
1geo's Avatar
Can't we all just . . . get along?
Old 08-02-2009, 02:42 PM   #26
You're asking a lot!
And now I'm going to ask a lot. . .
Mr. V., I'm asking you to look for, and find, at least one way that you and I are similar.
Old 08-02-2009, 03:58 PM   #27
DIYer
The ones I linked to that said manual reset do stay off. I needed to do the same thing you need.
Anyway if you are already half way done building a latching relay then keep going, just wanted to put that out there.
Old 08-02-2009, 04:38 PM   #28
Inquiry about manual reset
Yes, I want an outlet that will stay off if power is lost. My problem is I have a marine aquarium with a wet/dry filter. The filter is a large 4 gal sump that sits on the floor behind the aquarium. The sump has a pump in it that circulates the water back to the main aquarium. If power is lost, the suction from the main aquarium is gravity from an over flow box. Without the sump pump running the gravity suction feed is quickly broken because it would suck all the water out of the over flow box and no water would be returned to the aquarium by the sump pump because of the power lost. The problem come in when the power comes back on. The sump pump would start and quickly pump all of the the water in the sump back to the aquarium but the gravity suction feed would have been broken so no new water is entering the sump. The sump pump would remove the water from the sump and continue running dry until it destroyed itself. Ir the sump pump does NOT come back on then I could manually reestablish the gravity feed back to the sump before I turned the pump on.
I'll (attempt to) give you the setup without the schematic diagram. Hoping you'll figure out where the parts go! (Something I built/designed...assembled a long time ago for an alarm system). 1) 120/12v. transformer; 2)SPST or DPST (N/O) relay w. 12v. coil 120v. contacts; 3)Manual reset (drop down, N/C, 12v. Connected in series; 4) Connect one or both 120v. leads on contact (as oppose to Coil) terminals. Et Voila!!! (No matter what)(confusing? Not really)Don't Drink and Drive!!!
Last edited by spark plug; 08-02-2009 at 04:42 PM. Reason: Attempted to edit my caption
spark plug is offline   Reply With Quote
Old 08-02-2009, 05:19 PM   #29
Old 08-03-2009, 03:35 PM   #30
1geo
1geo's Avatar
Progress
I called seller, www.stayonline.com, and he verified that these outlet do trip on a power outage and need to be reset. Right now I have the outlet, schematic supplied by InPhase, finish with the exception of plugging in the relay which is on order. The total project cost is just over $20. When I get the relay I will post again.
Open circuit has power, close the circuit no power??? BeginnerHomeDIY Electrical 7 07-08-2009 02:40 PM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
pulling power from an outlet smcvey Electrical 6 03-21-2009 03:28 PM
safe way to add extension to power cord sil Electrical 7 10-18-2007 09:58 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 08:16 AM
