External Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2010, 09:20 PM   #1
Rewards Points: 81
External Ground
Dumb question. Is there any advantage to connecting an external ground for my washing machine and gas dryer? Both units have a 3 prong cord. The outlet is grounded. I did a continuity check from the ground off of the electrical outlet to the cold water pipe. 0 ohms. Wasn't sure if having an external ground provided additional safety / backup?
cougar01 is offline   Reply With Quote
Old 03-23-2010, 09:58 PM   #2
Rewards Points: 506
If the cord is properly connected to the machine, and the receptacle is properly connected and bonded, then I say there is no advantage to an external ground. Because of the poor conductivity of the earth, earth connections really provide little safety in the event of a fault.
The only advantage I can think that an extra earth connection would bring would be in the event of your machine receiving a direct lightning strike. What are the odds of that?
jlmran is offline   Reply With Quote
Old 03-24-2010, 08:29 AM   #3
Rewards Points: 2,800
If another ground rod is driven, it should be connected to the electrical system in the same manner the first ground rod and/or the incoming water pipe is so bonded, using a #6 copper wire. (A #4 wire is needed when the service is over so many amps, I forget the number.)
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 03-24-2010, 10:10 AM   #4
Licensed electrician
Rewards Points: 3,662
If you are asking about the small green wire that some machines had that connected to the screw on the trim plate the answer would be no. It is not needed. The third prong in the cord covers that function in a properly wired system.
Old 03-25-2010, 11:34 AM   #5
Rewards Points: 81
Thanks!
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 06:49 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 10:12 AM
Older home -- Open Ground issues, please help Toyz Electrical 1 06-15-2008 08:41 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 06:30 PM
