Extension Reel To Power On And Off Power Tools - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2014, 04:43 PM   #1
extension reel to power on and off power tools
Hi good people,
I bought a 12 gauge extension cord and a 15 amp reel with 4 outlets. The reel has a Resettable 15 A circuit breaker.
Aside from needing more length to reach the outlet, my purpose is to have a switch on/off of my circular saw.
I will be converting my circular saw into a table saw. I will clamp the trigger of the circular saw.
Is "Resettable 15 A circuit breaker" can be define as simple as on and off switch and is it safe to do this?
I bought the reel from canadiantire. ca I can't post links yet so this is the item # 52-2462-4.
willr is offline   Reply With Quote
Old 03-29-2014, 05:00 PM   #2
Oso954's Avatar
Rewards Points: 1,978
Your project sounds like an accident looking for a place to happen. (In more ways than one).
Take the cord reel back. While you are there, look at table saws.
Oso954 is offline   Reply With Quote
Old 03-29-2014, 05:14 PM   #3
Thanks for your reply. As far as electrical issue is concern, you think it's safe?
Old 03-29-2014, 05:31 PM   #4
dmxtothemax's Avatar
Rewards Points: 7,462
So you want to use the cut out on the power reel as the on / off switch for your
Home made table saw ?
Will it work ?
Yes !
How ever I suspect that the lifespan of the cut out will be short !
As they are not made for repeated operation.
dmxtothemax is offline   Reply With Quote
Old 03-29-2014, 05:32 PM   #5
Retired Moderator
Rewards Points: 7,174
No--the breaker button on the real is not heavy enough and will arc out of service.
If you are determined to do this--buy a 20 amp switch--mount it inside of an eclectic box--wired to an outlet---with a heavy gauge cord
A circular saw /table saw is about as dangerous as you can get---why ???
Please---buy a table saw----how are you going to adjust the height of the blade?
The Following 3 Users Say Thank You to oh'mike For This Useful Post:
dgfit (03-29-2014), Jim Port (03-29-2014), PaliBob (03-30-2014)
Old 03-29-2014, 11:35 PM   #6
Thanks for ur reply. I actually have a table saw but I can't have an accurate cut even after long hrs of fine tuning it. The diy table saw features and functions are well taken care of. My only issue now is the electrical safety.
So basically, adding a 20 amp switch to the 12g extension is a better idea?
Old 03-30-2014, 12:38 AM   #7
Not addressing the safety issue's of a home made table saw !
YES a proper switch is a better idea !
Old 03-30-2014, 04:04 AM   #8
Retired Moderator
yes.-----------
Old 03-30-2014, 04:17 AM   #9
But then again, I don't want to make a cut to my 12g extension cord Besides I don't have any experience in wiring....
Are these instructions credible enough? >>>
ehow.com/how_5101904_use-extension-cord-surge-protector.html
Old 03-30-2014, 04:21 AM   #10
Oh the problem might be the durability of the switch again? It's fine with me if it will only last up to three months, there should be enough money to buy a quality table saw by that time. Never to buy a cheap mastercraft brand again
Old 03-30-2014, 05:05 AM   #11
Rewards Points: 1,522
I've used a 15 amp outlet power strip for a switch on a band saw for years. The only disadvantage is the light I have for it is plugged into the strip also so no light until the saw is running.
The only codes I pay much attention to are ZIP CODES.
SeniorSitizen is offline   Reply With Quote
Old 03-30-2014, 05:10 AM   #12
With an extension cord?
Something like: Outlet>>extension cord>>surge protector>>power tool
Old 03-30-2014, 05:20 AM   #13
Yes Sir
Old 03-30-2014, 05:32 AM   #14
My extension cord is 12g but I can't seem to find a 12g surge protector, only 14g. Is there any compatibility issue with that? http://www.walmart.ca/en/ip/4-outlet.../6000109954969
Old 03-30-2014, 05:44 AM   #15
With that length the 14 ga. will be ok. It's probably heavier than the wire on the saw.
Shop around for outlets. I just bought a 2 pack of Stanley for 9.99.
