Extending Range Of Stove Electrical - Bad Idea? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-09-2010, 10:46 PM   #16
Electrician
Proby's Avatar
LOL, because he started the task before asking about it first
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
Old 08-09-2010, 10:49 PM   #17
Thumbs up
Originally Posted by Stubbie View Post
Proby
Just dropped in ... why is he chopping up range cords??
So I could run it to a junction box and connect it to the wiring that goes into my stove. May seem funny I know, but that was my best idea on how to extend the range at the time. With the help of more experienced and patient people (you guys) I am learning easier and better ways to do things. (Im new to this home improvement stuff... sorry
At least I am asking for advice from experts instead of just doing and hoping for the best.
sleepysmurf is offline   Reply With Quote
Old 08-09-2010, 10:56 PM   #18
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Hey no problem Sleepy. But I am glad you woke up ...
Your talking about aluminum wiring i assume this is the cable from the panel to the stoves old location (original branch circuit). If so how many wires 3 or 4 ??
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 08-09-2010, 10:57 PM   #19
Red face
PS. no one has commented on the way I am creating the link between the copper and the aluminum within the junction box. Am I missing anything other things ... other than the cap, the goop to rub into the aluminum and put into the cap twist it, wrap it in lots of electrical tape? Ive done copper to copper before but never copper to aluminum, im assuming its the same, other than you need the special goop (forget the name) and the special cap. correct?
Old 08-09-2010, 11:02 PM   #20
4 wires, ground (non shielded looking cable), hot (red), hot (black), and white (neutral)
I think thats how it goes.
As far as wiring it to the receptacle from what I understand the hots red and black attach to side pins, (it doesnt matter which side im told) the neutral white goes to the middle pin, and the ground attached to a screw that is within the box. Is this correct?
Old 08-09-2010, 11:15 PM   #21
Wink
My first plan was to buy 6 feet of copper wire, splice the wire, attach the 4 wires to the stove, use duct tape to keep the wires secure there, run the cord behind the counter using duct tape to secure it in place, and then on the other end of the copper wire, splice again get my 4 wires and insert them directly into the receptacle, again using duct tape to secure it all... wrap the entire cord in duct tape several times, around and around and around just to make sure it all sticks together and stick the cord to the wall with the attached duct tape. Then proceed to wrap the whole cord again in electrical tape.
This avoids ANY junction boxes. and provides a direct connection to stove to the wires in the wall. what more could go wrong?
Old 08-09-2010, 11:17 PM   #22
thanks guys for all your help! you guys rock! thanks again!
Old 08-09-2010, 11:17 PM   #23
Electrician
Proby's Avatar
I've seen worse. But that would have been a fire waiting to happen. With the amount of current your stove pulls thru those bad connections that you made, even your trusty duct tape wouldn't help contain the heat.
Old 08-09-2010, 11:46 PM   #24
" Euro " electrician
frenchelectrican's Avatar
I am little lost here but what did you make a spice between the copper and alum conductors ???
And in fact any transations of cable materals like from copper to alum or viceverisa you must have a juction box and that is no connires on this one.
And why you want to wrap the whole cord in electrical tape ?? that is inviting of overheated cord or cable.
Merci.
Marc
Old 08-09-2010, 11:48 PM   #25
UAW SKILLED TRADES
Stubbie's Avatar
Nope can't make the connection that way. There are special wire nuts that are purple but I wouldn't use them for extending a range cable. Range cables operate at very warm temps at times this is an aluminum connections worst enemy. You probably want something you can get at the local big box so go get a compression connector like the image.
These are alumniconn connectors for joining al to cu.
Stubbie
Old 08-09-2010, 11:51 PM   #26
Stubbie.,
I think the OP will need the Polairs connectors they are much bigger than what you show on the photo.{ of course some big box store should have them if not the electrical supply centre will have it }
Merci.
Marc
Old 08-10-2010, 12:02 AM   #27
UAW SKILLED TRADES
Stubbie's Avatar
Yeah your right marc
I was just looking and they don't make them to accept over #10 awg. thats what I get for trying to find something outside the electrical supply network. He could use it for his equipment ground connections.
Stubbie
Old 08-10-2010, 12:09 AM   #28
Of course but the OP still need junction box anyway
To OP here the photo what we are talking about.,,
And I will never use the big bleu wirenut for copper/alum connection like that.
Merci.
Marc
Old 08-10-2010, 12:27 AM   #29
UAW SKILLED TRADES
Stubbie's Avatar
Sleepy says he has a jb big enough for the wires sizes.He will probably have to order the polaris online or electrical house. May not like the cost. He needs 3 at least.
What else would big box carry? Maybe shrink tube and compression connector?
Stubbie
Old 08-10-2010, 01:17 AM   #30
Merci.
Marc
Im joking dudes... sorry im very sarcastic, im not that dumb... yes I dont know all the ins and outs about electrical but i know enough not to use duct tape LOL
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
3 prong range? laduehelp Electrical 39 03-11-2008 01:33 PM
Replacing Stove Top with Range the.vicster Electrical 3 02-23-2006 05:12 PM
