Extending Outlet To Add Another - Electrical - DIY Chatroom Home Improvement Forum
Old 04-17-2010, 01:08 AM   #1
Extending outlet to add another
Attempting to extend electrical outlet on East Wall to South Wall, adding the additional outlet on the South wall. Existing plaster walls. How to I push flexible conduit thru corner, 90 degree angle from the old outlet. Cannot go thru floor or thru upper floor of house, must go horizontal.
Do I just cut open the plasterboard, notch the studs for 3/4 inch conduit? Do I cut open the plasterboard and drill thru the studs to allow for passage of the conduit? Any special advice on the corners? Am I weakening the wood studs by cutting such a large hole or notch? Is there a simpler way?
Thanks in advance...
Wingingit is offline   Reply With Quote
Old 04-17-2010, 06:17 AM   #2
Wire or cable running thru studs must be 1 1/4" from the edge of the stud. If not, you must install a safety plate over the wire to pretect from nails/screws.
As for running a new wire from an existing outlet, if there is a basement below, drill thru the bottom plate and run the wire in the basement. If no basement, you will have to make holes for access as you describe. I usually use a large hole saw to make openings, then cover it with the piece that came out of the hole.
The Following User Says Thank You to Just Bill For This Useful Post:
Wingingit (04-17-2010)
Old 04-17-2010, 09:49 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 710
I would run 1/2" PVC conduit on the exterior of the building. Run it down low and paint the same as the building. Use a LB fitting to turn the corner. Or go into the ground and bury it and come back up at the new location if you cannot stand the look of the conduit. Wire with THWN conductors. You will need GFCI protection in any case.
My electrical answers are based on 2014 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
extending an outlet nel262 Electrical 18 02-08-2010 03:27 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
