Extending An Outlet - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-08-2010, 02:57 PM   #16
Learning by Doing
Leah Frances's Avatar
You should think about running a new wire with enough slack from the most adjacent Jbox or outlet. You are going to have the wall open, right? So, do it right!
Have fun with the demo - my advice about demolition is to have lots of trash bags ready and don't overfill them.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 02-08-2010, 02:57 PM   #17
Originally Posted by Scuba_Dave View Post
Yeah, I'd try to lower or raise the box
Do you have a crawl space or (finished) basement ?
I've put a junction box in the basement before & run new wire from there to the new box
I prefer to have splices easily accessible
Access from the finished basement will be tricky.Is bx stapled like romex?Just wondering if the cable can be pulled up or down.
Location is Bronx,New York
nel262 is offline   Reply With Quote
Old 02-08-2010, 03:07 PM   #18
These will be 2 exterior walls and each wall has 2 outlets on/in it.I know that the outlets are on 2 seperate circuits from a circuit map that I made when I moved in.So at the most I'm looking at running 2 new wires.Nothing is ever easy.
Old 02-08-2010, 03:27 PM   #19
Licensed electrician
Rewards Points: 3,662
The BX cable should be fastened similar to NM cable.
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
