Extend Wire From Fixture To Box - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2015, 12:10 PM   #1
Rewards Points: 54
Extend wire from fixture to box
Long story short I have a wiring box that is 20" off centre to the vanity, thus, I not only need to install a 40" wide fixture, but I also have an issue where the wires that come with the fixture will not reach the box. Can I splice in the box and then splice behind the fixture so it reaches?
kripes is offline   Reply With Quote
Old 10-11-2015, 12:27 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 796
All the splices must be in an approved box.
My electrical answers are based on 2017 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
Old 10-11-2015, 12:52 PM   #3
Rewards Points: 516
And those boxes must be accessible. Don't bury a box behind a finished wall.
Arrow3030 is offline   Reply With Quote
Old 10-11-2015, 02:52 PM   #4
Rewards Points: 54
Ok so I can put another box behind the centre of the fixture, ensure the splices occur only in each.
They are both accessible; they are simply behind the fixture backing (I am not drywalling them in)
The Following User Says Thank You to kripes For This Useful Post:
rjniles (10-11-2015)
Splice or replace entire wire? Septic Pump bsmith6356 Electrical 5 03-18-2013 06:44 PM
replacing ceiling fixture - hole in ceiling with wire hanging out sunshine1221 Electrical 4 08-20-2012 09:53 AM
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 02:37 PM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Installing light fixture.....ground wire? yummy mummy Electrical 15 02-19-2009 11:33 AM
