Exhaust Fan- Bathroom - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 07:19 PM   #1
Exhaust fan- Bathroom
I purchased an exhaust fan that states it is "UL Listed for installation over a tub or shower on a GFCI circuit".
Why would something that is required to to be GFCI protected, which would require it be on a dedicated 20 amp circuit, have both 16 and 18 ga. wire?
So, I would have to rewire the entire fan, go back and find a new fan or install another GFCI receptacle on a 15 amp circuit and be out of code?
Any advice????
ATShome1 is offline   Reply With Quote
Old 03-08-2010, 07:56 PM   #2
Just call me Andrew
Rewards Points: 1,032
There are different rules for manufacturers. Light/fan manufacturers are allowed to use smaller wire than homeowners, probably since the load on those devices is known.
Andrew
secutanudu is offline   Reply With Quote
Old 03-08-2010, 08:02 PM   #3
Remodeler
adpanko's Avatar
Rewards Points: 150
The gauge of the wires on the fan don't have to match the amperage of the circuit because the fan/light will only pull a low amount of amps; an amount that is small enough to safely travel on 16 and 18 gauge wire. Like most any light fixture you buy, the wire leads from the fixture are smaller than 14 gauge, yet they get twisted together with 14 or 12 gauge wire from the house circuit.
adpanko is offline   Reply With Quote
Old 03-08-2010, 08:06 PM   #4
NEC only covers home wiring
A 20a circuit can carry 2400w....your fan does not
GFCI can be a 15a circuit
Exhaust fans can be used anywhere
Suggestions for through-wall bathroom exhaust? frascati Electrical 1 11-04-2009 07:52 PM
Basement bathroom exhaust fan install krusty HVAC 5 09-15-2009 07:41 PM
Bathroom exhaust fans PirateKatz HVAC 7 11-18-2008 03:09 PM
Bathroom Exhaust Fan Ducting drtpdee HVAC 1 03-03-2008 06:47 PM
Bathroom Exhaust Fan Questions AllGoNoShow Remodeling 10 11-11-2006 07:59 AM
