Exhaust Fan - Electrical - DIY Chatroom Home Improvement Forum
Old 03-08-2010, 09:24 AM   #1
Smile
exhaust fan
I bought a new bathroom GE heater exhaust fan/light so can replace the old one I am having trouble connecting the wires from the wall switch to ceiling wires
thailand is offline   Reply With Quote
Old 03-08-2010, 09:37 AM   #2
Master Electrician
Rewards Points: 5,082
More info needed. What kind of trouble?
brric is online now   Reply With Quote
Old 03-08-2010, 10:04 AM   #3
Just call me Andrew
Rewards Points: 1,032
What color wires are in the switchbox? And at the fan?
Andrew
secutanudu is offline   Reply With Quote
Old 03-08-2010, 10:05 AM   #4
Rewards Points: 308
Correct More Info Needed.
1) How many wires in the ceiling box?
2) What color are they? (wires in the ceiling box)
3) Do you have one or two switches. One for the light and one for the fan or just one for both fan and light.
4) Whats the model number for the fan/heater.
5) Was there a fan and light there before.
Old 03-08-2010, 11:03 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 980
Be aware that if it is a heater, then it may require dedicated circuit.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 03-08-2010, 11:25 PM   #6
There are two armored cables- one for each side of the fan housing unit one of the cables has two wires (one black one white) The other cable has three wires (one red one white one black) There are seven wires inside the fan's wire connection box. Colors in box are three white wires, one red wire, one black wire, one yellow wire and one green ground wire. I only have one switch, The make is General Electric model # BFLH70L The same type of fan with a heater, fan and light was there before.
Old 03-09-2010, 11:13 AM   #7
Rewards Points: 308
Because you did not mark your wires so you would know how to re-connect the wires, I am going to give you the manual with the wiring instructions on it. This is the complete manual for the unit you have. If you still need help I will be back later today, maybe I should say. This will serve as a lesson to anyone that removes wires from any device, fixture or appliance to make sure they take notes or mark the wires.
Just take it easy and print out the 8 pages.
http://www.geindustrial.com/publibra...FLH70L|generic
Tags
electrical
whole house exhaust fan anybody gailquilter2 HVAC 14 06-29-2012 08:42 AM
Dryer exhaust/Bathroom exhaust fan nclooten HVAC 4 11-09-2009 10:45 AM
Can I T my new dryer's exhaust into my bathrooms exhaust? Felipon Appliances 2 01-30-2008 06:53 PM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 02:52 PM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 01:27 PM
