Error Message On My Generac 8kw - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Toller
Old 06-17-2017, 11:28 AM   #1
Rewards Points: 1,052
Error Message on my Generac 8kw
I have a 4 year old NG generator. There was a yellow light on, and the control panel says "overcrank alarm stopped". I googled and it seemed to be a significant problem.
I called the company that does my maintenance and they said that the yellow light comes on every year to show that maintenance is necessary. He told me to turn the switch to manual. It started up on the second crank. Now the green light is on and the message is gone.
He says it is fine; it is simply time for my yearly maintenance.
1) Is that true? I have read that the error message meant it tried to come on but couldn't.
2) The manual says it need maintenance every 2 years (or after heavy use). Is one year better?
Thanks.
Toller is offline   Reply With Quote
Old 06-17-2017, 01:00 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,680
Re: Error Message on my Generac 8kw
I've not heard of error messages pertaining to maintenance scheduling totally disabling a machine. Maybe an obnoxious light flashing, but not disabling. Now if there is somethng wrong, sure, shut it down.
Remember the TV or the refrigerator or dishwasher that died 3 days after the warranty expired? Certain things are built in such as predated obsolescence. But in your case, if it is working now, then they must have given you the right answer.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 06-17-2017, 01:15 PM   #3
Oso954's Avatar
Rewards Points: 1,810
It means that your generator failed to start.
Generac uses multiple start attempts. The ones I have worked with are 16 seconds followed by 7 seconds rest. The 5 cycles of 7 seconds cranking, each followed by 7 seconds rest. If your generator runs thru the whole series, you get the alarm.
The alarm clearing procedure used to be turning the auto/off/manual switch to off, then pressing enter. You can double check that in your manual. After clearing, placing the switch in auto should then restore normal operation.
You can then watch the unit and see if the problem re-occurs. If it does, a service is a good idea.
If the message shows up once a year to indicate service like the tech said, How come you haven't seen it before now ?
Oso954 is offline   Reply With Quote
Old 06-17-2017, 01:23 PM   #4
Super Moderator
joed's Avatar
Rewards Points: 23,540
Your generator did not start. You even had a problem in manual mode. It took two tries to start.
You need to find out why. The last thing you want is a no start when it counts.
I don't believe the light is for scheduled yearly maintenance but it does need service.
Old 06-17-2017, 01:57 PM   #5
The generator has never started on the first try. It usually starts on the second try. They claim that is usual.
Old 06-17-2017, 02:23 PM   #6
Super Moderator
joed's Avatar
I don't own a generac or work on them so I won't dispute whoever 'they' are. But normal combustion engines start on the first try unless there is an issue.
Old 06-17-2017, 03:49 PM   #7
Oso954's Avatar
I am getting a bad feeling about "They".
If you have another service company in the area, you might want to try talking with them.
While occasionally going into a second crank cycle isn't horrible, doing it on every start regardless of temp and weather conditions is not normal.
Your other avenue is to e-mail Generac explaining the two issues and what you were told. Ask them to confirm the answers.
Old 06-17-2017, 04:12 PM   #8
Rewards Points: 126
You might want to go to Ziller's Forum and read up on Generacs http://www.zillerstore.com/forums/
More knowledge about your generator might make you feel better. Or worse.
Jack
JACK HOTTEL is offline   Reply With Quote
Old 06-17-2017, 05:31 PM   #9
dmxtothemax's Avatar
Rewards Points: 7,426
QUOTE - [The generator has never started on the first try. It usually starts on the second try. They claim that is usual.]
WTF !
Maybe normal for Generacs !
But better generators do !
dmxtothemax is offline   Reply With Quote
Old 06-17-2017, 06:55 PM   #10
Super Moderator
joed's Avatar
After checking out the ziller forum I see that yellow flashing light can be a maintenance alert.
But over crank is not a maintenance issue. It is a fault.
http://www.zillerstore.com/forums/at...7&d=1271262020
Old 06-17-2017, 07:24 PM   #11
The yellow light is not flashing; it is solid.
An overcrank fault should be a red light. The first mystery is why it is yellow.
I looked on the log and it happened when we had power, so the generator should not have cranked.
I have sent this question to Generac and applied to post at Ziller.
mark_kershner likes this.
Old 06-17-2017, 09:57 PM   #12
Master Electrician
Rewards Points: 5,022
It will still crank for the exercise cycle with utility power still active.
brric is online now   Reply With Quote
Old 06-18-2017, 05:59 AM   #13
An old Tradesmen
Rewards Points: 7,746
Failed to start during a test/exercise period.
Generac oversensitivity davidrmoran Electrical 6 05-15-2016 07:17 PM
Generac 8kw Standby in the winter? Toller Electrical 7 08-01-2013 10:02 PM
Generac GP5500 a bust?? Ultrarunner2017 Electrical 11 12-21-2012 05:53 PM
Generac Install ????? herdfan Electrical 0 07-07-2012 05:01 PM
Generac 10KW generator and Generac RTS12EZA1 transfer switch. exhdo1 Electrical 8 11-30-2011 02:33 PM
