Entering Through Service Side Of Panel? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2016, 03:19 PM   #1
Rewards Points: 526
Entering through service side of panel?
I've read a couple of times that you are not allowed to run any wires/conduit/etc through the same side of the main panel that the service enters from, in my case it's the top of my main panel.
I've searched through the 2012 canadian electrical code and can't find any mention of that anywhere.
Could someone point me to the sections of Canadian/Ontario relevant code(s) and or NEC?
Killavolt is offline   Reply With Quote
Old 06-24-2016, 05:55 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 30,936
Re: Entering through service side of panel?
I can't find the code section but it is not part of the NEC.
Also there is a divider between the sections so you can't physically run the conductors without cutting it. That would not be an approved modification.
Old 06-24-2016, 06:03 PM   #3
Super Moderator
joed's Avatar
I think I found the relevent section
6-306 Consumer’s service raceways
Consumer’s service raceways shall
(a) contain only the consumer’s service conductors, and except where a deviation has been allowed in
accordance with Rule 2-030, only the conductors of one consumer’s service;
Old 06-24-2016, 06:51 PM   #4
Rewards Points: 526
The divider doesn't extend all the way to the back of the panel, there's room to run cables behind it. I can only assume that is the specific reason for the space behind it.
There's also room to the side of it as well which would allow cables to be run from the top to the bottom without issue.
I don't think that's referring to adding a conduit/feeders for a sub panel on the same side of the panel that the main service enters.
My interpretation of that section is that you can't run multiple services through the same conduit, and only one consumers service can run through one conduit.
That part is in a section about multiple services to the same residence as in the case of an apartment or multi family dwelling that has multiple meters. Basically saying that you can't use one panel for multiple services either.
Here is the code definition of a raceway:
Raceway — any channel designed for holding wires, cables, or busbars, and, unless otherwise qualified in the
Rules of this Code, the term includes conduit (rigid and flexible, metal and non-metallic), electrical metallic and
non-metallic tubing, underfloor raceways, cellular floors, surface raceways, wireways, cable trays, busways, and
auxiliary gutters.
"I kissed a light socket once and woke up in a helicopter"
Old 06-24-2016, 06:53 PM   #5
Rewards Points: 12
Deleted
Desertdrifter is offline   Reply With Quote
Old 06-24-2016, 09:03 PM   #6
Super Moderator
joed's Avatar
Go to the ESASAFE site and ask a question.
http://www.frontlines247.com/frontli...word=esatrade2
Old 06-24-2016, 09:05 PM   #7
Rewards Points: 526
I actually did that this morning before posting this thread but they won't answer over the weekend.
I was hoping someone here might have a solid answer for this before ESA got back to me.
I'll post back their answer when I receive it.
Old 06-27-2016, 01:01 PM   #8
Rewards Points: 526
Crap.
No. If the service conductor raceway enters the top of the panelboard, that space where the service conductors terminate to the main service breaker is considered the "service box". Rule 12-3032(1) does not permit branch circuit conductors to pass through the main service switch section of a combination panelboard.
Can I use a 200amp panel on a 100amp service / Is their a small 200 amp panel? 2x_Tom Electrical 5 01-03-2016 08:04 AM
Need help installing new service and making old service a sub panel fightermage Electrical 9 09-26-2012 08:48 PM
100amp service to 200amp service - double or single panel CapeCod153 Electrical 8 05-09-2012 08:03 PM
Upgrading Service/Moving Panel TheAcademician Electrical 17 09-13-2011 07:48 PM
Service move - old panel, separating neutral and ground WillK Electrical 3 06-17-2011 08:18 AM
