Emt Rain Proof Connectors - Electrical - DIY Chatroom Home Improvement Forum
Old 10-19-2015, 08:28 PM   #1
Lord of Slums
Rewards Points: 1,974
emt rain proof connectors
Why do none of the big box stores carry any sort of water tight 1/2 emt fittings? They only carry concrete tight. Can concrete tight be used in wet location
Pvc does not look good outside. My main question is do they sell pre made offsets for pvc? I do not want to bend pvc unless I have to. I will only use pvc as a last resort.
mj12 is offline   Reply With Quote
Old 10-19-2015, 08:47 PM   #2
Rewards Points: 18,808
All of them have water tight fittings.
There glue on, no different or less water tight the the PVC used in your drain lines.
Not sure what you mean by offsets, if your looking for the one that are slightly bent to go to a box mounted to a wall, yes they have those to.
The Gray PVC can be painted with latex paint.
Old 10-19-2015, 11:09 PM   #3
Licensed electrician
Rewards Points: 3,766
Most people shopping at the big box are not going to use raintight fitting or EMT. Anyone that needs those shops at a supply house.
mj12 (10-20-2015)
Old 10-20-2015, 05:05 AM   #4
Rewards Points: 6,652
It is not that they do not. It is that all of the packages get mixed together, from people just throwing them back into a random bin, instead of putting it back where they got them from.
If I cannot get it at the Ace Hardware store near me. I am driving a half mile down to the Electrical wholesaler and they have everything you need. They even have those odd items that have been on the shelf for a couple of years that they never know when someone may walk in and need it.
I always shop local for as much electrical stuff as I can, vs. going to the Big Box store. If I am buying from the Big Box, I am doing a huge project and just want to get everything at one stop.
Opinions of Ideal push-in wire connectors Bigplanz Electrical 62 07-03-2014 10:29 PM
using connectors with hydronic radiator boiler amakarevic Plumbing 0 11-04-2011 12:09 PM
Siding and rain screen Andee77 Carpentry 1 09-08-2011 08:28 AM
compressing RCA male connectors onto RG-6 cable amakarevic Electrical 0 01-03-2011 02:49 PM
Rain Gardens Colchicine Green Home Improvement 2 02-13-2009 06:35 AM
