Eletrical - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2010, 11:36 AM   #1
eletrical
im trying to figure out what my fuse panel is. the main fuse is a double 100amp so does that mean its 200 amp and also i figured out all the fuse sizes inside it add up too 390. the hydro meter outside says 200amp but is that just how much i can go up to.
tellie24 is offline   Reply With Quote
Old 11-28-2010, 11:40 AM   #2
A double 100a breaker means 100a on each hot leg
Not sure why the meter says 200a
Is there a garage or something that is also fed from the meter ?
Its common (expected usually) for the breakers to add up to more then the main breaker
The Following User Says Thank You to Scuba_Dave For This Useful Post:
tellie24 (11-28-2010)
Old 11-28-2010, 11:41 AM   #3
Rewards Points: 150
It's a double breaker because it's 240V, not 120.
You still have a 100-amp service.
Adding up the branch breakers does not give you any useful information. Start over again, and this time, instead of adding up the numbers on the handles, ask yourself how much current you actually USE on each circuit, and add those numbers up. Count every other row, total up that number. Then count the ones you skipped the first time and total up that number. If both numbers are far below 100, you're fine.
And remember that you don't use everything at once. Who runs the furnace and the air conditioner at the same time? And you probably don't run the dishwasher until AFTER you have finished with the dishes, which will likely be well after the food has been cooked and you're done with the oven.
emolatur is offline   Reply With Quote
The Following User Says Thank You to emolatur For This Useful Post:
Old 11-28-2010, 11:49 AM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 50
If your main fuses or circuit breaker says 100 amp then you have a 100 amp panel. The total of the installed fuses or breakers is not an indication of the capacity- it is always much higher than the panel capacity. Example the breakers in my 100 amp panel add up to 575 amps- a meaningless number.
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
The Following User Says Thank You to rjniles For This Useful Post:
Replacing an Eletrical Panel needs to break the dry wall? eirhur Electrical 8 08-26-2009 09:16 AM
eletrical philhvacr Electrical 8 05-03-2009 07:10 PM
Preparing for eletrical rough inspection? gone_fishing Electrical 10 01-07-2009 12:38 PM
eletrical katydid2000 Electrical 1 06-17-2005 07:18 AM
