Electronic Help Please - Electrical - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 2 Post By curiousB
  • 1 Post By jbfan
Old 02-09-2019, 11:20 PM   #1
i carved this sword
feralfreak's Avatar
Rewards Points: 169
Electronic help please
Im not sure if this is the right place, but I need some help with a project, i want to set up something for an led, with a battery backup, i can't give specifics because it is for an invention, i plan to use a charger for a cell phone as the plug in, but i dont know how to make the backup power supply, and i would like it to be rechargeable so in the event of a power outage it will still give light. Can someone tell me how to make the battery backup?
feralfreak is offline   Reply With Quote
Old 02-10-2019, 05:40 AM   #2
JUSTA MEMBER
Rewards Points: 1,166
Re: Electronic help please
Adapt one from any battery powered device using Ni-cad batteries, and a circuit with a control switch, that will actuate whenever there is an outage.
Look into uninterruptable power supplies for Computer applications, and copy them.
ED
de-nagorg is offline   Reply With Quote
Old 02-10-2019, 08:06 AM   #3
Rewards Points: 1,298
Design the circuit to only run from a battery then add in a charging scheme for the battery.
joed and FrodoOne like this.
curiousB is offline   Reply With Quote
Old 02-10-2019, 08:53 PM   #4
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,274
Check out the circuity of an emergency light. Does exactly like you want.
de-nagorg likes this.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Old 02-10-2019, 09:18 PM   #5
Semi-Pro Electro-Geek
Rewards Points: 3,642
Uh, the way you have the potentiometer drawn, it doesn't adjust anything, and you won't be putting an AC source in series with your battery. Not sure what's going on with that schematic...
Running from a rechargeable internal battery or from line power is a very standard thing to do, and there are a few different ways of doing it. Which way is the best for your application depends on all the details - which you have not provided. With the information you did provide, all I can say is that there are standard off-the-shelf solutions for this exact problem. Exactly which one you need depends on voltage, current, battery type, charging and discharging time, form factor requirements, and other stuff you're not telling us.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 02-11-2019, 05:15 AM   #6
Rewards Points: 2,670
mpoulton got in before me with the comment concerning the potentiometer.
This potentiometer is "tapped resistor" in the position where one would expect to find the current limiting resistor for a LED supplied from a constant voltage source.
In addition, potentiometers tend to be devices with very low Wattage dissipation - such as 100 mW, or less. Also, they tend to be of a greater resistance value than would be required by your "design", since the lowest available value which I can descern from a quick glance at a certain catalog is 1 kΩ.
Since you wrote "i would like it to be rechargeable so in the event of a power outage it will still give light" it seems to indicate that it may be that you intend to run the LED concerned at close to its maximum limits.
A 5 mm "Bright White" LED from that same catalog is rated at a maximum current of 30 mA with a voltage drop across the LED of 3.5 V.
If supplied from a 5.2 V source (because that would be about the voltage you would expect from "a charger for a cell phone"), the LED would require a current limiting resistor of at least 57 Ω - to dissapate about 51 mW.
Of course, as a designer, you should use a somewhat higher (Preferred Value) resister, to ensure that the LED is not supplied with more than 30 mA.
62 Ω, 68 Ω or 73 Ω half-watt resistors are possibilities in the case which I have described.
(A 1 kΩ potiometer used as a Rehostat would be much less suitable than a half-watt resistor and would be virtually certain to "burn out" within a short period.)
Of course, you wrote "i plan to use a charger for a cell phone as the plug in", which will supply DC and not AC.
FrodoOne is offline   Reply With Quote
Programmable electronic timer switch to electronic door lock? freedom1st1776 Electrical 19 03-10-2012 10:39 AM
looking for an electronic ball valve with timer tominator Plumbing 1 03-24-2011 01:05 AM
Trion HE 1400 Electronic Air Cleaner DwayneB HVAC 1 05-31-2010 09:23 AM
Electronic Ballast? fw2007 Electrical 9 03-18-2008 05:41 PM
