Electrician Says I Need To Replace Entire Panel - Please Help! - Electrical - Page 4 - DIY Chatroom Home Improvement Forum
Old 09-19-2009, 08:25 PM   #46
Rewards Points: 3,038
The instructions and/or a foil or metal name plate on the washer/drier unit should specify the amperes needed.
A 120 volt dryer will consume a little more in the way of watts compared with a 240 volt dryer due to loss in the wires.
Stop some of your bank autopayments so you can set priorities for manual monthly payments out of your coronavirus stimulus check.
Old 09-20-2009, 08:08 PM   #47
Thumbs up
The Zinsco/FPE saga continues...!
Originally Posted by frenchelectrican View Post
I save the youtube link and I will show it to you and you will see why from the Electrician point why want to ditch it in first place
This is Zinco but FPE { USA verison } will be simuair when they fail to trip on overload.
And I did show to couple of customers due some are pretty stubbon they won't want to upgrade until I show the youtube link as above in one second they changed their mind no question asked.
Now for the DIY's I know you will say OMG well., yes that true but keep in your mind the FPE in USA have issue but not the Canada verison they have no issue AFAIK .,,
Merci,Marc
In my experience with the FPE Panels and Breakers, they always tripped on overloads, NEVER on Ground faults, and very late (when the wire was very hot) on Short circuits. (No matter what) Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Adding ground bar to main panel WoodworkerDave Electrical 6 09-27-2008 04:52 PM
Replace main panel or use subpanel? MasterofNone Electrical 8 02-12-2008 12:24 AM
Multiple Sub Panel Installation Handyman2007 Electrical 26 12-31-2007 05:47 PM
breaker panel question chadvavra Electrical 11 08-10-2007 09:20 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
