Electrical Wiring Home ? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 07:12 PM   #16
Totally screwed together
Doubtful it is too powerful!
Those two black wires... does one of them have any ribbing on the side, something that makes it feel different from the other wire? If so, that is the neutral.
xxPaulCPxx is offline   Reply With Quote
Old 07-26-2010, 07:26 PM   #17
response
for the living room at home
both wires are basically the same,,,just one has writing on it and the other not
dcjcdc is offline   Reply With Quote
Old 07-26-2010, 08:42 PM   #18
Writing is neutral.
Old 07-27-2010, 07:23 AM   #19
Rewards Points: 5,348
Originally Posted by dcjcdc View Post
just remove dthe chandilier
but the old fixture on...and everything worked,,did not trip any fuse breakers....
maybe this chandiler is too powerful fur the breaker
The new chandilier is not too powerful for the breaker. It's possible the new fixture has a dead short in the wiring. Or when you pushed the wiring into the box, it shorted in the box. Look at all the wiring in the box. Check the sheathing for cuts or nicks.
Try taking a simple work light socket and attaching it to the box and just let it dangle. See if that works. If it does, the issue is in the fixture. Put a continuity meter on the fixture while it's on the table and see if it lights up. If it does, you have a short in the light.
Ron
Old 07-27-2010, 08:38 AM   #20
A "Handy Husband"
rjniles's Avatar
Rewards Points: 692
As an aside: when ever I install a new fixture (or a ceiling fan), before I fold the wiring into the box and secure the fixture to the box, I test to see if it works. If I have an issue after I button it up, I know I just caused it closing the box or installing the shroud
My electrical answers are based on 2014 NEC, you may have local amendments.
rjniles is offline   Reply With Quote
House electrical wiring issue. gnidaerd General DIY Discussions 5 06-07-2009 02:42 AM
Adding additional wiring to new block home sailorman Electrical 6 05-28-2009 01:27 PM
Polarized plug light fixture- Hardwire to home electrical? timdavis3824 Electrical 3 07-09-2007 12:34 PM
Electrical wiring running parellel and through ductwork? Beren HVAC 4 06-02-2007 12:32 AM
Electrical wiring running parellel and through ductwork? Beren Electrical 1 06-01-2007 04:08 PM
