Electrical Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2010, 07:42 PM   #1
j05
electrical wiring
How do you wire a red, black and white three wire cable to a fluorescent fixture with only black and white leads to the ballast?
j05 is offline   Reply With Quote
Old 11-20-2010, 08:53 PM   #2
I suspect you are going to have to put a bit more effort into this one.
oberkc is offline   Reply With Quote
Old 11-20-2010, 09:22 PM   #3
Rewards Points: 2,800
Using a voltmeter, verify that there are 0 volts from white to ground. Also verify 120 volts from black to white and/or 120 volts from red to white.
Then connect the white wire of the cable to the white wire of the fixture and connect either the red or black wire (must have measured 120 volts) to the black wire of the fixture. Cap off the other loose wire.
If the fixture does not have a built in switch you will want to add a switch, disconnecting the black wire from the wire going to the cable and connecting the switch between these loose ends. If the switch is some distance away and connected by a new previously unmentioned 2 wire cable, connect the colored wire of that cable to the black wire of the fixture.
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
electrical wiring new construction 63Falcon Electrical 1 11-07-2010 03:31 PM
electrical wiring home ? dcjcdc Electrical 19 07-27-2010 08:38 AM
electrical wiring jess123 Electrical 10 01-02-2010 06:58 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
How can I tell if there is electrical wiring beneath kitchen tiles? Mr T Electrical 8 01-04-2009 04:40 PM
