Electrical Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 02-19-2010, 02:17 PM   #1
electrical wiring
How do you connect a 240V electric cooktop with three wires to the 240V service from the electric panel which is 4 wires?
lamalex is offline   Reply With Quote
Old 02-19-2010, 02:21 PM   #2
Super Moderator
joed's Avatar
Rewards Points: 24,048
Cap the white wire from the panel and don't use it.
Connect the the ground wire from the cooktop to the bare ground from the panel.
Connect the two hots from the cooktop to the red and black wires from the panel.
Old 02-19-2010, 02:21 PM   #3
Licensed electrician
Rewards Points: 3,662
If the cooktop is 240 volt only, not 120/240, you would connect the black and reds to the cooktop leads and connect the grounds together. Just cap the white and tuck it out of the way in the box.
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 11:16 AM
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 07:40 PM
wiring help needed for rangehood electrical installation. kimchidaddy Electrical 1 01-12-2009 06:19 AM
Electrical problem, bad wiring? mumblemouth Electrical 10 08-09-2008 11:52 AM
Electrical wiring running parellel and through ductwork? Beren HVAC 4 06-02-2007 12:32 AM
