Electrical Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 08-12-2013, 07:27 PM   #1
Electrical Problem
I got a Problem with a Couple Regular Outlets, I have no power to either 1, But when I hook up a Gauge I get a weak Light, So It getting a Bleed through Right? What is Causing this, I need to Fix Its driving me Crazy...
splinter2 is offline   Reply With Quote
Old 08-12-2013, 07:50 PM   #2
Rewards Points: 150
Sounds like a loose neutral and or backstabbed outlet connections. Pull the outlets and look for any loose wires
romex1220 is offline   Reply With Quote
Old 08-12-2013, 09:07 PM   #3
Rewards Points: 18,488
Need a volt Ohm meter to do any real testing. Even a chap one would be better then a test light.
Old 08-12-2013, 09:23 PM   #4
dmxtothemax's Avatar
Rewards Points: 7,748
What did you use for the test ?
Non contact testers and digital type meters can give false readings !
Known as "Phantom voltage"
You most likely got a bad / loose connecttion.
Or a thrown gfci hidden somewhere behind a shelf
or pile of box's. (very common).
dmxtothemax is offline   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
gregzoll (08-14-2013)
Old 08-12-2013, 10:15 PM   #5
Rewards Points: 150
My money's on a tripped gfi
The Following User Says Thank You to romex1220 For This Useful Post:
gregzoll (08-13-2013)
Old 08-13-2013, 07:58 AM   #6
Rewards Points: 6,652
Second on bad or tripped GFCI outlet. Where are these outlets located in your residence?
Old 08-13-2013, 11:03 PM   #7
Loose/intermittent connections - when there is almost no load - can check out okay with a voltmeter. But put a load on it, and a poor connection (assume 5 ohms) starts heating up as you draw a load - and that is one of the causes of fires! To be conservative, you could isolate the circuit when you are not troubleshooting that branch....to eliminate the risk.
To troubleshoot - you might have to pull all the outlets out of the wall and let them 'hang out' ...and check the wiring. Outlets might be daisy-chained...find the first one - find the last one ...the last one has wires coming in - and none leaving. Put a load on the outlet at the end of the string ...maybe 250 to 500 watts (at least 1 light, and maybe a small heater or other) - then go back to the other outlets that are hanging out and tap/wiggle the other outlets while having someone watch the light. If the light starts going on/off with the tapping - you might have found the suspect outlet.
vineyardmh is offline   Reply With Quote
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
Do I have a major electrical problem? teamcampreder Electrical 12 07-30-2011 09:33 AM
wife tried to fix electrical problem :-\ mikahtx Electrical 14 08-11-2010 01:35 PM
Electrical receptacle problem centralhome Electrical 13 12-27-2008 01:45 PM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
