Electrical And Plumbing In Same Stud Bay? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2010, 07:43 PM   #1
Electrical and Plumbing in Same Stud Bay?
Hi there,
New here but been reading as a guest for a while now. Lots of great advise. Just looking for some input here. I have a shower that backs up to our master bedroom. In this wall there is electrical for a wall mounted TV and a receptacle below. There is also copper water lines for the shower. I highlighted the ones I'm mainly concerned about where there is electrical below plumbing in the picture below. Is this safe? Is it even allowed by code. I'm in NJ. I really do not wantto get electrocuted while taking a shower should a shower head leak. Any input would be greatly appreciated.
Why wife is concerned by my father in law and brother in law seem to think it is ok. Thanks.
Tim
timcurtin is offline   Reply With Quote
Old 12-05-2010, 08:22 PM   #2
Licensed electrician
Rewards Points: 3,658
No issues, this is done all the time.
Old 12-05-2010, 10:26 PM   #3
Yup. I agree w/ Jim.
VIPlumber is offline   Reply With Quote
Old 12-07-2010, 12:28 PM   #4
Thanks guys .
Do you think it would be wise to at least change the receptacles in the bedroom behind the shower to GFCI? I'm thinking at a minimum the one that is directly below the left showerhead. I'm less concerned about the one higher up on the wall that I am plugging the TV in as if that shower head drips it will miss the outlet box as it is not in direct alignment.
Thoughts?
Tim
Old 12-07-2010, 12:46 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
A) What will GFI protecting the receptacles on the other wall do?
B) What danger do you think exists by having the wiring and pipes in the same bay?
Old 12-07-2010, 02:29 PM   #6
A. if water drips from the shower head and gets into the receptacle box, it would immediately trip the circuit
B. if there is a leak and water finds its way to the receptacle is it possible to be electrocuted? I don't think so, but my wife wants me to ask. She doesn't believe anything I say it seems.
Old 12-07-2010, 03:04 PM   #7
Completely 100% false.
Not at all likely if the electric is installed properly.
Sure, water and electricity don't mix, but it is NOT the instant death, jump out and bite you, scenario most think it is.
If some scared folks realized the typical water/electricity relationship in a average home they'd never move in.
Old 12-07-2010, 04:22 PM   #8
Registered User
Termite's Avatar
Petey's 100% right. This should not be a concern, nor is it a code violation. GFCI protecting those receptacles on the other side of the wall won't accomplish anything. If you're concerned about dripping/leaking in the future, use some sheet metal or wood to create a barrier between the two systems (if it makes you feel better).
I would not have any concerns about this setup.
Old 12-07-2010, 04:29 PM   #9
Thanks for the validation. I showed my wife your responses and she feels much better now and I even think she feels a little bad she doubted me.
Tim
Old 12-07-2010, 04:43 PM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 958
Tim
Is she going to let you live it down that you told the whole world she didn't beleive you???
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
Is this OK? Electrical near plumbing kahuna44 Electrical 1 08-10-2010 11:28 AM
bathroom, electrical, plumbing in 1 week jeeper Project Showcase 15 10-09-2009 02:13 PM
Electrical Next to Plumbing MikeyP Electrical 8 12-08-2008 04:11 PM
Aquapex Plumbing in proximity to electrical Randell Tarin Electrical 6 03-18-2008 04:21 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 08:55 PM
