Electrical Panel Move ? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-09-2012, 12:24 PM   #1
noshoff
electrical panel move ?
Move an electrical panel? Panel is now located in a bedroom closet with a low ceiling. I wish to raise the ceiling height and make a hallway. However, the wiring is streched so tight out of the low ceiling closet I can't seem to push it up far enough to get the ceiling at the right height. What can I do to get additional slack in the wiring?
shadowbuilder is offline   Reply With Quote
Old 01-09-2012, 12:28 PM   #2
Julius793's Avatar
Leave the old panel as a junction box and you have no problem.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following 2 Users Say Thank You to Julius793 For This Useful Post:
gregzoll (01-11-2012), shadowbuilder (01-09-2012)
Old 01-09-2012, 12:35 PM   #3
J. V.'s Avatar
Rewards Points: 512
An accessible junction box.
J. V. is online now   Reply With Quote
The Following 2 Users Say Thank You to J. V. For This Useful Post:
gregzoll (01-11-2012), shadowbuilder (01-10-2012)
Old 01-10-2012, 10:15 PM   #4
noshoff
I have not detailed the situation accurately. I don't see how a junction box raises all of the conductors,coming out of the panel for the entire house, high enough to install the proper height ceiling.
Old 01-10-2012, 10:33 PM   #5
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,652
Originally Posted by shadowbuilder View Post
I don't see how a junction box raises all of the conductors, coming out of the panel for the entire house, high enough to install the proper height ceiling.
Use the OLD PANEL as a junction box.
Leave it where it is, install a DIFFERENT panel where you want...
and then extend all the wires between the two.
Old 01-11-2012, 06:31 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 18,206
OP's title is a little wrong.....what I think he is really asking is how to make the wires longer so that it clears the hallway he wants to make.
shadowbuilder....basically, you have to make a decision....move your existing load center or add a junction box so you can extend your wires. In either case, your most likely going to need a junction box. In other words, all the wires going into your load center need to be made longer....so your going to have to pull them all out, run them to a junction box out of the way AND accessible and then run from the junction box to your load center.
And if your going through that much work, it might be a good time to move the load center to a better location that you know will be out of the way.
That is basically what I had to do when I upgraded my electrical from 60a to 200a 11 years ago.
Old 01-11-2012, 07:11 AM   #7
Semi-Pro Electro-Geek
Rewards Points: 3,666
Especially since panels in bedroom closets are a code violation, and closets in general often make achieving the working space requirements very difficult. Unless the new hallway you're making is completely replacing the closet, you will have to put the panel elsewhere. Substantially modifying the panel (like by removing and extending all of the wires) would definitely require that you bring the installation up to current code.
mpoulton is offline   Reply With Quote
Old 01-11-2012, 07:49 PM   #8
noshoff
Mpoulton, Thanks for your help. I am completely replacing the closet with hallway six foot by three foot
Old 01-11-2012, 08:07 PM   #9
noshoff
You got my hallway and need for longer wires understood. Thanks. I am afraid you are telling me to disconnect eveything at the existing load center and find a spot to reconnect everything to a new load center. Then run the power only from the old(existing) load center to the new located load center. Is this a rewire of the whole house?
Old 01-11-2012, 08:55 PM   #10
Electrical Contractor
jbfan's Avatar
Rewards Points: 6,674
Are all the wires feed from the top, or are some fed from the bottom?
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
Old 01-11-2012, 10:35 PM   #11
noshoff
all from the top jbfan, thru the floor joists, over and under the hvac, hidden above the sheetrock, etc. Thanks for asking.
Old 01-12-2012, 06:22 AM   #12
jbfan's Avatar
Raise the panel, and this will give you slack to raise the ceiling.
PIctures may help also.
Old 01-12-2012, 06:49 AM   #13
noshoff
This may be the best advice yet! It stil must b work easy. How high for code?
Old 01-12-2012, 07:13 AM   #14
Licensed electrician
Rewards Points: 3,766
The highest breaker cannot be above 6'-7" to the center of the handle.
Old 01-12-2012, 09:12 AM   #15
noshoff
Thank you Jim.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
Electrical Panel Positioning Lseguin Electrical 12 01-20-2011 07:09 AM
Electrical Sub Panel Grounding KellyElaine Electrical 17 01-17-2011 06:46 PM
Fireblocking around electrical service panel dbmjmj Building & Construction 0 07-11-2010 05:51 PM
Electrical Panel "cut-in" question Todd-sta Electrical 52 12-03-2008 11:07 PM
