DIY Chatroom Home Improvement Forum (https://www.diychatroom.com/)
-   Electrical (https://www.diychatroom.com/f18/)
-   -   electrical panel grounding (https://www.diychatroom.com/f18/electrical-panel-grounding-88587/)
Terrence Blanch 12-04-2010 01:53 PM
Can I put two ground wires in the same terminal of the panel ground strip
McSteve 12-04-2010 02:30 PM
Usually, yes. But you have to check the panel label to be sure. It should list how many of each size wire you can put in each ground terminal.
Note that you can't do this with neutrals, those need to be one wire per hole.
LyonsElecSupply 12-04-2010 04:37 PM
I thought it was one wire per screw on anything unless otherwise identified as such.
nap 12-04-2010 04:42 PM
that is what McSteve said.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
