Electrical Outlets / Light Switches Not Working - Electrical - DIY Chatroom Home Improvement Forum
Old 11-14-2017, 09:25 AM   #1
Rewards Points: 2
Electrical outlets / Light switches not working
Hello all, let me start off saying I am a novice.
The problem I am having is that the outlets and light switches on a certain circuit all have stopped working. The circuit breaker is fine and receiving 120 volts.
Part of the circuit are as follows:
1 Light switch
2x outlets
3x ceiling lights
The one light switch controls the 3 lights.
I used a multimeter on the one outlet and got 120v when I held the leads to the white wire and the copper wire, and 120v when I held the leads to the black wire and copper wire.
On the other outlet I only got 120v when I held the leads to the black wire/copper wire and nothing when I held the leads to the white/copper.
Any troubleshooting tips here would be appreciated. Thank you very much!
shanghei is offline   Reply With Quote
Old 11-14-2017, 09:49 AM   #2
Super Moderator
joed's Avatar
Rewards Points: 31,904
Re: Electrical outlets / Light switches not working
loose connection somewhere.
Turn off the circuit breaker and pull out the non working receptacle and look for a loose connection. If the wires are connected via the back stab pushin connectors move them to the screws. If no problems in the bad receptacle then check the working one.
Pre installed Light Switch with one wire to it - can electrical outlets be between HTFreak Electrical 7 08-22-2017 09:01 PM
Light Switch Replacement - Other Outlets Not Working cuerp0 Electrical 3 10-09-2012 10:48 PM
Light switches and outlets stopped working. jeweladdict Electrical 4 08-13-2012 10:51 AM
Hot Light Outlets Materials Guru Electrical 5 07-31-2006 07:11 PM
Replacing light killed downstream outlets, totally stuck amissner Electrical 5 07-13-2006 06:02 AM
