Electrical Outlet Install - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2010, 02:56 PM   #1
When I test new outlet with multimeter putting both probes in I get 10VAC, but when I put red probe in EITHER slot and black probe on ground wire I get the 120VAC. The outlet does not work, and it's new and wired correctly I believe..white wire to silver, black to brass. Any help would sure be appreciated.
nlb3rd is offline   Reply With Quote
Old 10-22-2010, 03:25 PM   #2
Rewards Points: 330
connect meter to screws and see what you get.if all you did was replace outlet,it may be bad.
oleguy74 is offline   Reply With Quote
Tiling around HALF an electrical outlet Patless Electrical 10 10-07-2009 10:39 AM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 02:44 PM
Outlet install in Cabinet? jamiedolan Electrical 5 09-28-2008 01:35 AM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 04:09 PM
moving an electrical outlet bobo Electrical 4 05-21-2005 12:15 PM
