Electrical Lawn Mower Question - Electrical - DIY Chatroom Home Improvement Forum
Old 08-16-2015, 12:48 PM   #1
Rewards Points: 1,062
electrical lawn mower question
People,
have a rider mower, MTD, and want to bypass solenoid and all the safety switches. Instead of jumping the starter with battery cables from my car, want to install a toggle switch switching directly from battery red hot wire to red wire to starter.
So, what amperage toggle switch would I need if battery is cold cranking amps of 365? Also, what size braided wire (guage??) would I need?
Thanks,
Quack
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 08-16-2015, 01:29 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 202
Most responders on this forum are safety minded and will be reluctant to help with your project.
My electrical answers are based on 2014 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Jim Port (08-17-2015)
Old 08-16-2015, 01:52 PM   #3
Super Moderator
joed's Avatar
Rewards Points: 30,164
You need at least a 400 amp switch. You should not be bypassing the start solenoid.
The Following User Says Thank You to joed For This Useful Post:
noquacks (08-16-2015)
Old 08-16-2015, 03:42 PM   #4
Thnaks, joed. Why shouldnt I bypass the solenoid?
Old 08-16-2015, 04:39 PM   #5
Master Electrician
Rewards Points: 5,190
The solenoid is the relay switch. How do you propose to shut the engine off?
brric is online now   Reply With Quote
Old 08-16-2015, 05:32 PM   #6
Rough Rooster's Avatar
Rewards Points: 412
You are either trying to start something or you don't understand electricity. Your starter draws more current than a typical toggle switch can tolerate, so the starter current is routed through solenoid which is capable of handling high currents as required by starter. The solenoid is a relay. When you apply power to it through ignition switch it is energized and an electromagnet closes the circuit between battery and starter with a set of contacts large enough to carry the necessary current to operate starter.
That is the purpose of solenoid. It is a switch with large enough contacts to handle the starter.
If you persist in your suggested use of a toggle switch for starter, it will overheat to the point you can't turn it off, and you will most likely burn your lawn tractor.
Good luck!
RR
Rough Rooster is offline   Reply With Quote
Old 08-17-2015, 06:48 AM   #7
Rewards Points: 1,332
Here is a link to a switch that would work Not sure where or how you would mount it though...
http://www.southlandelectrical.com/i...FVM7gQodUjEAkA
danpik is offline   Reply With Quote
Old 08-17-2015, 12:26 PM   #8
Rewards Points: 2,600
two pieces of perhaps #0 battery cable can work, you simply leave the two ends open (they form the switch) and when you need start you hold them together. you can cap the battery side end with a empty 20oz water bottle, etc.
concrete_joe is offline   Reply With Quote
Old 08-17-2015, 12:40 PM   #9
Rewards Points: 2,350
In this case, since such a starting scheme means that only the OP will likely be involved, I'm all for letting natural selection do its job.
broken lawn mower, now what? jason41987 Landscaping & Lawn Care 12 06-04-2012 06:15 PM
Lawn mower starts then dies gazz87 Landscaping & Lawn Care 8 11-19-2011 02:43 PM
Lawn mower repair ibgyahoo General DIY Discussions 1 08-04-2011 12:48 PM
Solaris Lawn Mower review dive_instructor Landscaping & Lawn Care 0 06-03-2011 10:29 AM
Important Wire Nut and Electrical Tape Question Wolfies167 Electrical 22 01-06-2010 01:59 PM
