Electrical Inspection - Electrical - DIY Chatroom Home Improvement Forum
Old 01-21-2010, 10:57 AM   #1
electrical inspection
When having an electrical inspection do you need to have all receptacles, switches,fixtures installed and working or is it OK to simply have the wire run from box to box as necessary.
Also when installing boxes in exterior walls you usually have to first put in a plastic boot or vapour boot. Is it ok to use the blue plastic boxes that are air tight without the plastic vapour boot?
Thank.
beech is offline   Reply With Quote
Old 01-21-2010, 11:06 AM   #2
Where are you located ?
Where is the wiring - kitchen, garage, basement ?
Rough Inspection here outlets are not installed
They go in after insulation inspection & then sheetrock goes up
I've never installed a vapour boot
Old 01-21-2010, 11:06 AM   #3
First you run your wires and connect the grounds together. This is called "rough" wiring. The inspector comes out to inspect this first.
Then you install the outlets, switches, fixtures, and cover plates and turn on power. This is called "finish". The inspector comes out a second time for this inspection.
Billy_Bob is offline   Reply With Quote
Old 01-21-2010, 11:13 AM   #4
Household Handyman
Rewards Points: 1,412
See- -depends on location and local codes. Here it's a "rough-in" inspection then a "final" inspection, pretty much as Billy_Bob described. David
Old 01-21-2010, 11:36 AM   #5
Thaks for the replies. Can I do my drywall after the rough inspection?
Old 01-21-2010, 11:37 AM   #6
PS I am in Ontario Canada
Old 01-21-2010, 12:04 PM   #7
Super Moderator
joed's Avatar
Rewards Points: 23,958
Drywall goes up after rough inspection.
Old 01-21-2010, 12:14 PM   #8
Ask your local electrical inspection department to be sure...
Old 01-21-2010, 02:17 PM   #9
Rewards Points: 1,016
I like to have a preinspection/discussion with the building inspectors when starting a project to have definitive answers to these types of questions. Then with each inspection I discuss next steps, next inspection needs, etc. Gets them involved, makes sure you are doing what they are looking for, etc. - makes it easier on everyone involved, IMHO.
Old 01-21-2010, 04:16 PM   #10
Thanks all for all your help. I really appreciate it.
Old 01-21-2010, 05:35 PM   #11
Inspector/Instructor
codeone's Avatar
Depending if you have had any other necessary inspections you made need.
Such as framing , insulation>
codeone is offline   Reply With Quote
Electrical Inspection mike6679 Electrical 5 01-09-2010 10:35 AM
Rough electrical inspection - passed today! THANKS!!! vsheetz Electrical 4 02-06-2009 10:42 PM
Electrical issues with home inspection toolmaan Electrical 20 08-10-2007 05:52 PM
How is electrical inspector doing the inspection... KUIPORNG Electrical 2 08-15-2006 08:46 PM
Yay! Passed my electrical inspection today! MikeinBurien Electrical 2 12-17-2005 02:32 PM
