Electrical Help Please. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 08:06 PM   #1
Electrical help please.
So i went to install a new light fixture in my dining room. Most of my experiences with electrical work has been very cut and dry. One black wire, one white wire and one ground wire (green or bare). So i open this box up and what the heck??????????? Volt reader always found life.
Additional, it seems that my kitchen lighting is running through here, and also my back patio light.
What should i do?????
beericus is offline   Reply With Quote
Old 01-10-2010, 08:19 PM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
Not enough detail in the picture to really see what is going on. So your old light worked fine?
When you say the volt reader always found life, do you mean that ALL of the colors of wire were hot???
adpanko is offline   Reply With Quote
Old 01-10-2010, 08:19 PM   #3
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
Pretty simple, actually.
The wires you disconnected from the previous fixture get attached to the new fixture.
Makes sense doesn't it?
The red is likely the switch leg and of course those whites spliced together is your neutral connection.
Don't be intimidated and never start taking everything apart unless you know what you're doing.
Union County, NJ, Licensed Electrician
Classic Electric, LLC, Rahway, New Jersey
Magnettica is offline   Reply With Quote
Old 01-10-2010, 08:25 PM   #4
Thanks guys,
Yes the Volt Reader kept going off, and even sparked and made the lights flicker in the rest of the house when i touched the cluster of white wires.
yes it seems simple enough, when you know what your doing. I dont know what i am doing.\
and yeah the old fixture worked fine.
Old 01-10-2010, 08:28 PM   #5
Magnettica's Avatar
Rewards Points: 150
The lights were flickering because as that neutral splice comes apart it breaks the circuit. You'd be best off turning off that circuit before proceeding.
Old 01-10-2010, 08:30 PM   #6
i turned the switch off at the breaker, but it was still reading on the volt pen.....
Old 01-10-2010, 08:39 PM   #7
It is a good idea to always turn off the main power to the house before doing any electrical wiring. Some electrical boxes have wiring from more than one breaker in them. And sometimes breakers are marked wrong.
Use battery operated lighting to see your work if necessary.
Billy_Bob is offline   Reply With Quote
Old 01-10-2010, 08:41 PM   #8
Magnettica's Avatar
Rewards Points: 150
Sometimes those "volt pens" aren't very reliable. All they do is detect a magnetic field. If you're still not sure, turn off all the circuit breakers. But I would suggest you don't turn off the main breaker especially if you have an older panel.
Old 01-10-2010, 08:42 PM   #9
Learning by Doing
Leah Frances's Avatar
You've got a problem if you're still hot after switching the breaker. May be the breaker you think controls the light does not, may be something is wired incorrectly. To save yourself a lot of running to and fro I'd start by enlisting the help of an assistant - get on your cell phones and try and figure out if you've got the right breaker (and, hopefully not, that more than one breaker is involved).
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 01-10-2010, 09:03 PM   #10
Some wiring in homes is called a MWBC or a Multi-Wire Branch Circuit. In this case, the power is controlled by two circuit breakers.
Old 01-10-2010, 09:05 PM   #11
I did what you said here man, i think i got it, will let you know in a few minutes
Old 01-10-2010, 11:12 PM   #12
finished thank you guys!!! i just never saw that configuration in a box before. Im no electrician............ Thanks again....
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 06:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
