Electrical Boxes For Metal Studs - Electrical - DIY Chatroom Home Improvement Forum
Like Tree3Likes
  • 1 Post By hkstroud
  • 1 Post By HandyAndyInNC
Old 03-11-2019, 01:26 PM   #1
Rewards Points: 640
Electrical boxes for metal studs
I need to bulk order electrical boxes for outlets for metal studs for a new installation. Studs are 3 5/8". Electrical is being run with Metal clad cable. MC lite.
I'm in nyc so i need metal boxes with side clamps.
What size and depth should I get?
Also anyone know of boxes that have a bar that braces on the wall behind it so the box doesn't flex when pushing plugs into the outlet.
jaketrades is offline   Reply With Quote
Old 03-11-2019, 01:33 PM   #2
hkstroud's Avatar
Rewards Points: 5,544
Re: Electrical boxes for metal studs
I would just screw a short piece of 2x4 to the metal stud and attach a regular nail up box to that.
jaketrades likes this.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 03-11-2019, 02:01 PM   #3
Rewards Points: 470
I have always used a regular or deep 4x4 box with a single or double device ring. You will think yourself later when you have to deal with the conduit or the amount of wires in each. If you use conduit all the way to the box, that will give it extra support.
You do not want to hammer on the metal stud, they are not that strong.
Andrew
Handy Andy In Mt Airy NC
HandyAndyInNC is offline   Reply With Quote
Old 03-11-2019, 02:04 PM   #4
Rewards Points: 640
Andrew
Yeah I was thinking about getting the 1900 boxes 4x4 with device rings. Iíll look for some with side clips.
Yeah I hated working in those small outlet boxes.
Old 03-11-2019, 02:08 PM   #5
Rewards Points: 470
Make sure to get some short self-tapping screws.
Me too, I always try to make things easy for myself when it comes to this.
Andrew
The Following User Says Thank You to HandyAndyInNC For This Useful Post:
jaketrades (03-11-2019)
Old 03-11-2019, 02:42 PM   #6
CodeMatters's Avatar
Rewards Points: 6,142
Here's a box made for the purpose:
Use "wafer" screws to attach wing to metal stud.
CodeMatters is online now   Reply With Quote
Old 03-11-2019, 04:37 PM   #7
Electrician
Rewards Points: 898
Use the box mentioned above, it is designed for steel studs.
The part on the left wraps around the back of the stud and the wing on the right will hit the drywall after install to prevent box from flexing.
darren is offline   Reply With Quote
Old 03-11-2019, 04:48 PM   #8
Licensed electrician
Rewards Points: 3,592
You can use these with 1900 boxes and plaster.rings.
https://www.garvinindustries.com/han...saAtwuEALw_wcB
Old 03-11-2019, 08:15 PM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 540
That's what I use and I short panhead screws.
Yes I am a pirate, two hundred years too late
The cannons don't thunder, there's nothing to plunder
I'm an over-forty victim of fate.
jbfan is online now   Reply With Quote
How far should electrical boxes stick out to account for tile backsplash? Studly Electrical 20 02-12-2019 10:31 AM
Shallow Electrical Boxes l008com Electrical 46 11-22-2018 06:17 AM
Making outside light electrical boxes waterproof wewantutopia Electrical 8 12-26-2014 09:50 AM
Hole locations in metal electrical boxes miamicuse Electrical 1 08-18-2013 02:55 PM
Can I cover unwanted electrical boxes (ie switch box) with drywall?? DanDaMan Electrical 15 03-07-2011 02:59 AM
