Electrical Box Dimensions? - Electrical - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By rjniles
Old 07-11-2016, 02:34 PM   #1
Rewards Points: 4
Electrical box dimensions?
I am having holes predrilled in sheet metal for 4" octagonal junction boxes. I can't find any exact dimensions anywhere for the mounting holes. Does anyone know these dimensions or is anyone able to point me to where they may be?
Thanks,
Christian
cmkniat is offline   Reply With Quote
Old 07-11-2016, 02:44 PM   #2
Oso954's Avatar
Rewards Points: 1,882
Re: Electrical box dimensions?
You need to commit to a specific make and model.
Dimensional drawings are available from most mfg. some are available online. Here is one example.
http://www.garvinindustries.com/down...4151-1-2-a.pdf
Oso954 is offline   Reply With Quote
Old 07-11-2016, 02:54 PM   #3
Rewards Points: 4
The boxes I used are the 4" octagonal boxes from Steel City that I purchased through Home Depot online. Is there no standard trade size? And could you resend that link please? I think it was broken by a ...
Best regards,
Old 07-11-2016, 03:31 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 896
Best regards,
Give a box to whomever is making the holes to use as a template.
Oso954 likes this.
My electrical answers are based on 2017 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Jim Port (07-11-2016)
Old 07-11-2016, 03:59 PM   #5
Oso954's Avatar
Best regards,
4inch octagonal is the trade size. But Steel City lists about 40 different models with different combinations of depth, brackets, number of KOs, size of KOs, internal clamps, etc. Some of the mounting holes do move around based on some of these options.
Best bet is RJ's suggestion, give the guy doing the work a box to use as a template and tell him which holes you want to use for mounting. No sense having him drill them all.
Old 07-11-2016, 05:15 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 2,006
A 4" octagon box is a 4" octagon box. The mounting holes are 3.5" apart.
There is no mystery here. The only variable is the depth.
Old 07-11-2016, 05:19 PM   #7
The box above is made by this guy:
Tags
dimensions , electrcal box
Electrical Connection for Backyard Pond drelldrell Electrical 1 06-24-2015 05:25 AM
Is a separate electrical subpanel required for a guest house? eholmes77 Electrical 11 02-10-2015 06:30 PM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
