Electrical Box Behind Dishwasher - Electrical - DIY Chatroom Home Improvement Forum
Old 05-09-2010, 10:47 PM   #1
Ok, so the electrical box for my dishwasher is on the wall near the floor directly behind where my dishwasher will be located.
Now that I've been looking at installation manuals for a bunch of dishwashers I see that specify that the box be in an adjacent cabinet...
Can anyone expound on the reasining for this? Is it a safety issue or just a space issue?
Since my electrical box is flush with the wall, I could theoretically (Option A) put a cover on it and run a wire to another box in the adjacent cabinet. Only thing is that that seems a little silly, since I could also just (Option B) run the line right out of the electrical box into the dishwasher.
I'm not going to be able to run another supply so if anyone can give me their thoughts on the best way to deal with this I would be extremely appreciative.
Thanks,
BrooklynDIY
BrooklynDIY is offline   Reply With Quote
Old 05-10-2010, 05:53 AM   #2
Just call me Andrew
Rewards Points: 1,032
I'd just plug the d/w into the box you have, but you might want to do it with a plug instead of hard-wired. Make the cord a little extra long and you can pull the dishwasher out if necessary.
Andrew
secutanudu is offline   Reply With Quote
Old 05-10-2010, 06:00 AM   #3
Often, dishwashers are hardwired, no box with a plug. I suspect the reasoning behind no box behind the DW is they need all the space behind them that is available. If you use a flat(right angle) wall plug, it might work.
Old 05-10-2010, 09:38 AM   #4
Mad Scientist
I believe the reasoning, at least with a cord & plug connected dishwasher, is that you should be able to disconnect the power to the DW without having to pull it out from the cabinets.
McSteve is offline   Reply With Quote
Dishwasher electrical question 83trekker Electrical 9 01-10-2010 09:24 AM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
Dishwasher installation Andy Griffith General DIY Discussions 3 03-02-2009 06:06 AM
dishwasher electrical wire feb Electrical 31 04-12-2008 10:04 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
